Aller au contenu principal
Introduction
This guide will teach you how to remove the Cover on your HP Officejet Pro 6835 or 6830 to reach the main components.
  1. Open the main lid as far as it will go.
    • Open the main lid as far as it will go.
    • Use a plastic opening tool to gently pry off the hinge on the right side by pushing it to the left and off the hook.
    • Open the lid further.
  2. Use a T9 torx screwdriver to remove a total of ten (10) 12mm screws from the main cover by turning the screwdriver counterclockwise. The two screws above the screen assembly are deep so you may need a long screwdriver. The two screws above the screen assembly are deep so you may need a long screwdriver.
    • Use a T9 torx screwdriver to remove a total of ten (10) 12mm screws from the main cover by turning the screwdriver counterclockwise.
    • The two screws above the screen assembly are deep so you may need a long screwdriver.
  3. Grab the main cover and lift it up slightly.
    • Grab the main cover and lift it up slightly.
    • Do not pull too hard—there is a cable connecting the cover to the printer.
  4. Grab the base of the white ribbon cable connecting the cover to the base of the printer and pull it out. Grab the base of the white ribbon cable connecting the cover to the base of the printer and pull it out.
    • Grab the base of the white ribbon cable connecting the cover to the base of the printer and pull it out.
Jake Park
Membre depuis le 24/01/2018
451 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S2-G4, Livingston Winter 2018 Membre de l'équipe Cal Poly, Team S2-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G4
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 56
