Aller au contenu principal
HP Officejet Pro 8620 Printer Head Replacement
  1. HP Officejet Pro 8620 Printer Head Replacement, Printer Head: étape 1, image 1 de 1
    • Open the printer head cover door by pulling the cover door.
    • Power on the printer. This will move the print head to the left so you can access it.
    • Unplug the power cable from the back of the printer.
    • Do not power down the printer using the power button, as this will cause the printhead to move back to the right, making it incaccessible.
  2. HP Officejet Pro 8620 Printer Head Replacement: étape 2, image 1 de 2 HP Officejet Pro 8620 Printer Head Replacement: étape 2, image 2 de 2
    • Locate the printer head on the left side of the printer.
  3. HP Officejet Pro 8620 Printer Head Replacement: étape 3, image 1 de 2 HP Officejet Pro 8620 Printer Head Replacement: étape 3, image 2 de 2
    • Pull the white plastic tab on the right of the printhead toward you on an upward swing to unlock the printhead.
  4. HP Officejet Pro 8620 Printer Head Replacement: étape 4, image 1 de 2 HP Officejet Pro 8620 Printer Head Replacement: étape 4, image 2 de 2
    • Gently pull out the printer head.
13 autres ont terminé cette réparation.
Scott
Membre depuis le 01/24/18
593 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S19-G2, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S19-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S19G2
1 membre
6 tutoriels rédigés
15 commentaires
Did not work for me on my HP 8620.
Sam Cauchi - Réponse
Do you sell the replacement print head box for the HP Officejet pro 8620?
Do you post to England?
Thanks Pat Trotter
Pat Trotter - Réponse
How about always paperjam and printhead just moving by 1 inch
Setiawan Ayooservice - Réponse
Replacing easy.
BUT. Can it be repaired? Someone real experience with it?
PS. Of course only as no physical damage from outside and all 4 ink chambers (1) still sealed properly and (2) never have run empty
lbruederlin - Réponse
Did not work for me. Followed the instruction and re installed the printhead. Same issue.
abenani2000 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 53
30 derniers jours : 233
Total : 23,367
