Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
If your HP Officejet Pro 8625 display is blank or not turning on, you can replace the display motherboard using this guide. You will need a T9 Torx screwdriver and a T6 Torx screwdriver for the screws in this guide.
Pièces
Aucune pièce spécifiée.
  1. Disconnect the display by holding it in place while pulling down on the plastic hinge. Slowly apply more and more force as it does take a lot to separate, do not worry about the hinge or display breaking.
    • Disconnect the display by holding it in place while pulling down on the plastic hinge.
    • Slowly apply more and more force as it does take a lot to separate, do not worry about the hinge or display breaking.
  2. Lift the display as high as it will allow to expose the back of the display. Pinch the sides of the cover and pull away from the printer to reveal the connector. Remove the connector by pulling both away from the display and towards the printer.
    • Lift the display as high as it will allow to expose the back of the display.
    • Pinch the sides of the cover and pull away from the printer to reveal the connector.
    • Remove the connector by pulling both away from the display and towards the printer.
  3. Kits pour Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Remove the four 6.2 mm T9 screws from the back of the display. Pull the display assembly up and away from the printer. Pull the display assembly up and away from the printer.
    • Remove the four 6.2 mm T9 screws from the back of the display.
    • Pull the display assembly up and away from the printer.
  5. Remove the back cover from the display assembly by pressing down on the point of connection. If you use a plastic spudger for this step, be careful not to brake the plastic as you do not need to use much force to remove the back cover.
    • Remove the back cover from the display assembly by pressing down on the point of connection.
    • If you use a plastic spudger for this step, be careful not to brake the plastic as you do not need to use much force to remove the back cover.
  6. Remove the four 4.8 mm T6 screws from the back of the display motherboard. Remove the four 4.8 mm T6 screws from the back of the display motherboard.
    • Remove the four 4.8 mm T6 screws from the back of the display motherboard.
  7. Remove the connection on the front of the display motherboard. Remove the display motherboard.
    • Remove the connection on the front of the display motherboard.
    • Remove the display motherboard.
Daniel
Membre depuis le 08/10/2018
244 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S13-G3, White Fall 2018 Membre de l'équipe Cal Poly, Team S13-G3, White Fall 2018
CPSU-WHITE-F18S13G3
3 membres
7 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 63
