Introduction
Use this guide to replace the battery in a HP Omen 15-5002xx. The battery is an essential component to keep the computer on using energy inside the battery. Charging the computer is needed for the battery to work.
Before beginning, be sure to completely shut down the computer and unplug from the charger.
Ce dont vous avez besoin
Flip the laptop upside down so the backside is facing up.
Use a spudger or your fingers to remove the thin rubber strips that are attached from the edges of the laptop.
Unscrew all 14 screw with the J00 JIS Screwdriver.
Open the case slowly from opposite sides of the laptop.
Use the J00 JIS screwdriver to remove eight screws securing the battery.
