Aller au contenu principal
HP Omen 15-5002xx Battery Replacement
Ce dont vous avez besoin
  1. HP Omen 15-5002xx Battery Replacement, Back Cover: étape 1, image 1 de 2 HP Omen 15-5002xx Battery Replacement, Back Cover: étape 1, image 2 de 2
    • Flip the laptop upside down so the backside is facing up.
    • Use a spudger or your fingers to remove the thin rubber strips that are attached from the edges of the laptop.
    • Remember where each thin rubber came from and set them off to the side.
    • Unscrew all 14 screw with the J00 JIS Screwdriver.
  2. HP Omen 15-5002xx Battery Replacement, Battery: étape 2, image 1 de 1
    • Open the case slowly from opposite sides of the laptop.
    • Use the J00 JIS screwdriver to remove eight screws securing the battery.
  3. HP Omen 15-5002xx Battery Replacement: étape 3, image 1 de 2 HP Omen 15-5002xx Battery Replacement: étape 3, image 2 de 2
    • Carefully remove the battery connector that is attached to the motherboard by slowly sliding it towards the battery with two fingers.
    • Remove the battery by lifting it up and out.
Eduardo Arellano
Membre depuis le 09/01/21
621 Réputation
5 tutoriels rédigés
Équipe
Gateway, Team 1-1, Saknee Fall 2021 Membre de l'équipe Gateway, Team 1-1, Saknee Fall 2021
GCC-SAKNEE-F21S1G1
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 14
Total : 522
