Aller au contenu principal
HP Omen 15-5002xx Keyboard Replacement
Ce dont vous avez besoin
  1. HP Omen 15-5002xx Keyboard Replacement, Back Cover: étape 1, image 1 de 2 HP Omen 15-5002xx Keyboard Replacement, Back Cover: étape 1, image 2 de 2
    • Flip the laptop upside down so the backside is facing up.
    • Use a spudger or your fingers to remove the thin rubber strips that are attached from the edges of the laptop.
    • Remember where each thin rubber came from and set them off to the side.
    • Unscrew all 14 screw with the J00 JIS Screwdriver.
  2. HP Omen 15-5002xx Keyboard Replacement, Battery: étape 2, image 1 de 1
    • Open the case slowly from opposite sides of the laptop.
    • Use the J00 JIS screwdriver to remove eight screws securing the battery.
  3. HP Omen 15-5002xx Keyboard Replacement: étape 3, image 1 de 2 HP Omen 15-5002xx Keyboard Replacement: étape 3, image 2 de 2
    • Carefully remove the battery connector that is attached to the motherboard by slowly sliding it towards the battery with two fingers.
    • Remove the battery by lifting it up and out.
  4. HP Omen 15-5002xx Keyboard Replacement, Fan: étape 4, image 1 de 1
    Outil utilisé dans cette étape :
    Flathead 1.5 mm Screwdriver
    $5.49
    J'achète
    • Remove the twelve big screws with the J00 JIS screwdriver.
    • Remove all eight small screws with the 1.5 flathead screwdriver.
  5. HP Omen 15-5002xx Keyboard Replacement: étape 5, image 1 de 2 HP Omen 15-5002xx Keyboard Replacement: étape 5, image 2 de 2
    • Carefully detach the fan connector that is attached to the motherboard by slowly sliding the connector out with two fingers.
    • Remove the battery carefully.
  6. HP Omen 15-5002xx Keyboard Replacement, Wi-Fi Card: étape 6, image 1 de 1
    • Use the Phillips #00 to remove one screw securing the Wi-Fi Card.
  7. HP Omen 15-5002xx Keyboard Replacement: étape 7, image 1 de 1
    • Carefully remove the Wi-Fi Card by slowly sliding the card sideways away from the motherboard.
  8. HP Omen 15-5002xx Keyboard Replacement, Motherboard: étape 8, image 1 de 1
    $5.49
    J'achète
    • Use the 1.5 flathead screwdriver and remove the twelve screws from the motherboard.
  9. HP Omen 15-5002xx Keyboard Replacement: étape 9, image 1 de 3 HP Omen 15-5002xx Keyboard Replacement: étape 9, image 2 de 3 HP Omen 15-5002xx Keyboard Replacement: étape 9, image 3 de 3
    • Disconnect the four cables attached to the motherboard.
  10. HP Omen 15-5002xx Keyboard Replacement: étape 10, image 1 de 2 HP Omen 15-5002xx Keyboard Replacement: étape 10, image 2 de 2
    • Disconnect the remaining four connectors from the motherboard.
    • Remove the motherboard.
  11. HP Omen 15-5002xx Keyboard Replacement, Keyboard: étape 11, image 1 de 1
    $5.49
    J'achète
    • Remove all 51 screws using the 1.5 mm flathead screwdriver from the underside of the keyboard.
    • All necessary screws are numbered from 1-51 on the side of each screw hole.
  12. HP Omen 15-5002xx Keyboard Replacement: étape 12, image 1 de 2 HP Omen 15-5002xx Keyboard Replacement: étape 12, image 2 de 2
    • Slowly pull the electricity tape off of the computer.
    • You are able to replace the electricity tape or keep the tape attached with the wire.
  13. HP Omen 15-5002xx Keyboard Replacement: étape 13, image 1 de 2 HP Omen 15-5002xx Keyboard Replacement: étape 13, image 2 de 2
    • With two hands, lift the keyboards from the sides.
Hassan Isse
Membre depuis le 09/01/21
97 Réputation
1 tutoriel rédigé
Équipe
Gateway, Team 1-1, Saknee Fall 2021 Membre de l'équipe Gateway, Team 1-1, Saknee Fall 2021
GCC-SAKNEE-F21S1G1
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 20
30 derniers jours : 60
Total : 1,115
