Aller au contenu principal
HP Omen 15-ax243dx Hard-Drive Replacement
Ce dont vous avez besoin
  1. HP Omen 15-ax243dx Hard-Drive Replacement, Battery: étape 1, image 1 de 2 HP Omen 15-ax243dx Hard-Drive Replacement, Battery: étape 1, image 2 de 2
    • The rear panel is secured by 10 screws. Using a #00 Phillips Screwdriver, remove the ten 1.2 mm screws.
    • The screwdriver should be inserted at the same angle as the screws.
    • Be sure to keep track of the screws and where they came from. Some only fit in to one spot.
  2. HP Omen 15-ax243dx Hard-Drive Replacement: étape 2, image 1 de 2 HP Omen 15-ax243dx Hard-Drive Replacement: étape 2, image 2 de 2
    • Insert a plastic opening tool between the rear panel and the top case. Pry the opening tool upwards to separate the top case from the bottom case.
    • Slide the opening tool along the case perimeter to loosen the bottom case.
    • Gently pull the bottom case away from the laptop.
  3. HP Omen 15-ax243dx Hard-Drive Replacement: étape 3, image 1 de 2 HP Omen 15-ax243dx Hard-Drive Replacement: étape 3, image 2 de 2
    • Remove the four 1.2 mm Phillips #00 screws around the battery.
  4. HP Omen 15-ax243dx Hard-Drive Replacement: étape 4, image 1 de 2 HP Omen 15-ax243dx Hard-Drive Replacement: étape 4, image 2 de 2
    • Pull the battery cable out from its motherboard socket.
    • Pull parallel to the motherboard, not straight up.
    • Remove the battery.
    • Disconnect the power cord from the battery and transfer it to your replacement battery.
  5. HP Omen 15-ax243dx Hard-Drive Replacement, Hard-Drive: étape 5, image 1 de 1
    • After the battery is removed, the hard drive will be easier to access in the top right hand corner.
  6. HP Omen 15-ax243dx Hard-Drive Replacement: étape 6, image 1 de 3 HP Omen 15-ax243dx Hard-Drive Replacement: étape 6, image 2 de 3 HP Omen 15-ax243dx Hard-Drive Replacement: étape 6, image 3 de 3
    • With a opening tool, flip open the switch that locks in the hard drive ribbon cable into the device.
    • When lifting the cable out, lift straight up and out to prevent damage to the connector or cable.
  7. HP Omen 15-ax243dx Hard-Drive Replacement: étape 7, image 1 de 1
    • Lift the hard drive up to remove from the device
  8. HP Omen 15-ax243dx Hard-Drive Replacement: étape 8, image 1 de 3 HP Omen 15-ax243dx Hard-Drive Replacement: étape 8, image 2 de 3 HP Omen 15-ax243dx Hard-Drive Replacement: étape 8, image 3 de 3
    • Remove the rubber guards on the side of the hard drive.
    • Gently pull the plastic connector out from the hard drive.
    • The hard drive can now be disposed of if needed.
    • Save the guards and connectors from this hard drive, they will be used on the replacement part.
3 autres ont terminé cette réparation.
vangnam
Membre depuis le 10/19/17
594 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S6-G7, Rockett Fall 2017 Membre de l'équipe UMass Dartmouth, Team S6-G7, Rockett Fall 2017
UMASSD-ROCKETT-F17S6G7
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 57
Total : 8,193
