Aller au contenu principal
HP Omen 15-ce019dx Battery Replacement
Ce dont vous avez besoin
  1. HP Omen 15-ce019dx Battery Replacement, Battery: étape 1, image 1 de 3 HP Omen 15-ce019dx Battery Replacement, Battery: étape 1, image 2 de 3 HP Omen 15-ce019dx Battery Replacement, Battery: étape 1, image 3 de 3
    • Unplug the computer and power it off completely.
  2. HP Omen 15-ce019dx Battery Replacement: étape 2, image 1 de 3 HP Omen 15-ce019dx Battery Replacement: étape 2, image 2 de 3 HP Omen 15-ce019dx Battery Replacement: étape 2, image 3 de 3
    • Turn the laptop over so the bottom is facing up.
    • Remove the eight 1.2 mm screws around the frame using a Phillips #00 screwdriver.
    • Unscrew the two 1.2 mm screws at the top using a Phillips #00 screwdriver. These screws stay in the back of laptop, so when you hear a clicking sound, the screw is removed and you may proceed.
  3. HP Omen 15-ce019dx Battery Replacement: étape 3, image 1 de 3 HP Omen 15-ce019dx Battery Replacement: étape 3, image 2 de 3 HP Omen 15-ce019dx Battery Replacement: étape 3, image 3 de 3
    • At the top of the laptop, there is gap between the back cover and the rest of the laptop.
    • Gently pop the back off by gripping the top edge where the gap is and pulling up. The rest of the frame should pop up as you pull.
    • There should be popping sounds as the frame comes up around all the edges.
    • It will take some force to remove the frame for the first time. Don't be afraid to really pull it up; just be patient and don't rip it up all at once. Each edge should pop up as you pull.
  4. HP Omen 15-ce019dx Battery Replacement: étape 4, image 1 de 1
    • Remove the four 1.2 mm screws from the top of the battery using a Phillips #00 screwdriver.
  5. HP Omen 15-ce019dx Battery Replacement: étape 5, image 1 de 2 HP Omen 15-ce019dx Battery Replacement: étape 5, image 2 de 2
    • Pull up on the battery from the top, and slide it out of place.
2 autres ont terminé cette réparation.
Ashley Hanna
Membre depuis le 11/19/20
175 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 42
30 derniers jours : 204
Total : 5,259
