Aller au contenu principal
Introduction
A damaged reflective document mat can produce poor quality images. You can replace this mat in a few simple steps.
Pièces
Aucune pièce spécifiée.
  1. Grasp the scanner lid cover from the front of the device and lift lid all the way up until it stands on its own.
    • Grasp the scanner lid cover from the front of the device and lift lid all the way up until it stands on its own.
  2. With two hands, grasp the lid on both sides near the hinges and lift straight up to release the lid from each hinge.
    • With two hands, grasp the lid on both sides near the hinges and lift straight up to release the lid from each hinge.
  3. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
  4. Once the lid has been removed, lay it on a flat surface with the white mat facing up.
    • Once the lid has been removed, lay it on a flat surface with the white mat facing up.
    • Using the flat end of a plastic spudger, pry the mat off at one of the front corners. Do this again for the other front corner.
  5. Once both front corners have been released from the plastic clasps the rest of the mat should easily lift off. Recycle or discard the damaged mat.
    • Once both front corners have been released from the plastic clasps the rest of the mat should easily lift off.
    • Recycle or discard the damaged mat.
Amber Gabaldon
Membre depuis le 28/01/2014
325 Réputation
3 tutoriels rédigés
Équipe
New Mexico State, Team 1-4, Sheppard Spring 2014 Membre de l'équipe New Mexico State, Team 1-4, Sheppard Spring 2014
NMSU-SHEPPARD-S14S1G4
3 membres
4 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 486
