Aller au contenu principal
HP Pavilion - 17 g173ca Disassembly to access RAM and Hard drive
Ce dont vous avez besoin
  1. HP Pavilion - 17 g173ca Disassembly to access RAM and Hard drive, HP Pavilion - 17 g173ca Disassembly to access RAM and Hard drive: étape 1, image 1 de 2 HP Pavilion - 17 g173ca Disassembly to access RAM and Hard drive, HP Pavilion - 17 g173ca Disassembly to access RAM and Hard drive: étape 1, image 2 de 2
    • Start by disconnecting the power cord, then turn over and remove the battery
    • There are a large number of screws visible on the bottom, they are all the same size and length, remove them all.
    • There are two screws hidden under silver stickers, indicated by the orange circles, remove the stickers and the screws underneath.
  2. HP Pavilion - 17 g173ca Disassembly to access RAM and Hard drive: étape 2, image 1 de 1
    • Remove the optical drive, if all the screws have been removed is should slide out easily.
  3. HP Pavilion - 17 g173ca Disassembly to access RAM and Hard drive: étape 3, image 1 de 3 HP Pavilion - 17 g173ca Disassembly to access RAM and Hard drive: étape 3, image 2 de 3 HP Pavilion - 17 g173ca Disassembly to access RAM and Hard drive: étape 3, image 3 de 3
    • Use a guitar pick to release the plastic clips at the points shown on the black covers near the hinges.
    • If you just pry the black covers off a small clip will break but the clips are not important.
    • Once the covers are off, remove two more screws from underneath the covers.
    • All of the screws are the same as the ones already removed.
  4. HP Pavilion - 17 g173ca Disassembly to access RAM and Hard drive: étape 4, image 1 de 1
    • Turn the laptop back upright and open the lid
    • Using a guitar pick, release the plastic retaining clips that hold the bottom of the case on.
    • Release the areas marked with green first, then the yellow and last the orange.
    • Close the lid and turn the unit upside down again.
    • The bottom cover should now be free, lift the front part first and push the cover toward the hinges.
    • If the cover resists make sure you have removed all the bottom screws including the two hidden under stickers.
  5. HP Pavilion - 17 g173ca Disassembly to access RAM and Hard drive: étape 5, image 1 de 3 HP Pavilion - 17 g173ca Disassembly to access RAM and Hard drive: étape 5, image 2 de 3 HP Pavilion - 17 g173ca Disassembly to access RAM and Hard drive: étape 5, image 3 de 3
    • With the bottom cover removed the hard drive and RAM are easily accessible.
    • The hard drive is held in only by friction,
    • To remove the hard drive from its mount lift the drive a bit from the end near the data and power cables
    • Disconnect the power and data cables, the cable is a delicate ribbon cable so be gentle, don't pull it out or the way too far.
    • Lift the cable end a bit more and slide the drive towards the ram a bit to release the clips holding down the other end.
    • the mounting frame can just be pulled free from the drive, it is also only attached by friction.
  6. HP Pavilion - 17 g173ca Disassembly to access RAM and Hard drive: étape 6, image 1 de 1
    • When reassembling, keep the unit upside down and slide the bottom cover back into place hinges first.
    • It is a little fiddly getting the clips near the hinges and battery compartment seated.
    • Once the hinge area is close to being tight enough to push the clips back together, run your fingers down the sides by the keyboard to clip the sides and front.
    • Turn the unit upright open the lid and slide your fingers along the edge under the display and all the way around the edge to be sure all of the clips are back in place.
    • Reinstall the optical drive.
    • Turn the unit upside down again.
    • Replace the screws that will be hidden under the black covers by the hinges.
    • Replace the black covers by the hinges and then all of the rest of the screws. Don't forget the cover stickers for the two hidden screws.
32 autres ont terminé cette réparation.
rmac
Membre depuis le 11/17/12
1 230 Réputation
2 tutoriels rédigés
22 commentaires
Very good tutorial. The cover is a pain to open but with your input, it worked great.. thanks!
Mario Levesque - Réponse
Now, I must ask, how do I replace the keyboard??? Can it be done?
dgolson45 - Réponse
I don't have access to one of these right now, the one used for the guide was in for an upgrade, but looking at my photos it looks like there is a metal plate under the mainboard that holds the keyboard in place and it looks like it is held in place by melted plastic.
It that is the case, the official method would be a replacement assembly that includes the keyboard the retaining plate and the cover plate that the keyboard mounts through, moving all the electronic bits over.
The MacGyver method, (if you can get a replacement keyboard alone) would be to remove all the parts that block the keyboard retaining plate, break it loose to remove the dead keyboard and use glue to reattach the retaining plate.
If you have a heat gun (SMC rework station) you may be able to use it to soften the plastic retainers during removal and smash them back down later with a soldering iron but that basically never works.
rmac - Réponse
Great tutorial. I got water on my laptop and had to get inside to dry it out. Worked just like you said!! Thanks!
Susan Black - Réponse
Worst tutorial ever
Clifford Taylor - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 46
30 derniers jours : 218
Total : 81,839
