Aller au contenu principal
HP Pavilion 11 x360 Battery Replacement
Ce dont vous avez besoin
  1. HP Pavilion 11 x360 Battery Replacement, Remove Screws: étape 1, image 1 de 2 HP Pavilion 11 x360 Battery Replacement, Remove Screws: étape 1, image 2 de 2
    • Use the spudger to pry off the two rubber feet near the hinge of the laptop. This will reveal two hidden 9mm screws.
    • You must remove eleven screws.
    • Four 9mm screws with the PH0 screwdriver.
    • Seven 6mm screws with the PH0 screwdriver.
  2. HP Pavilion 11 x360 Battery Replacement, Remove Backing: étape 2, image 1 de 3 HP Pavilion 11 x360 Battery Replacement, Remove Backing: étape 2, image 2 de 3 HP Pavilion 11 x360 Battery Replacement, Remove Backing: étape 2, image 3 de 3
    • Use the spudger to pry the corners of the laptop near the display hinges.
    • Pry around the seam of the laptop with the plastic opening tool until the backing begins to pull apart.
    • When you lift the bottom cover, there is a cable connected between the motherboard and the bottom cover. Be careful not to pull the cable loose!
  3. HP Pavilion 11 x360 Battery Replacement, Detach Cable: étape 3, image 1 de 2 HP Pavilion 11 x360 Battery Replacement, Detach Cable: étape 3, image 2 de 2
    • Use the plastic opening tool to lift the white tab up at the connection.
    • Pull the cable outwards.
  4. HP Pavilion 11 x360 Battery Replacement, Battery: étape 4, image 1 de 1
    • Remove the four 6mm screws from the battery with the PH0 screwdriver.
  5. HP Pavilion 11 x360 Battery Replacement: étape 5, image 1 de 3 HP Pavilion 11 x360 Battery Replacement: étape 5, image 2 de 3 HP Pavilion 11 x360 Battery Replacement: étape 5, image 3 de 3
    • Use the spudger to pry up the blue/white speaker wires that are routed beside the battery.
  6. HP Pavilion 11 x360 Battery Replacement: étape 6, image 1 de 2 HP Pavilion 11 x360 Battery Replacement: étape 6, image 2 de 2
    • Remove the battery cable from the motherboard by gently pulling out on the black part of the cable closest to the white tab.
  7. HP Pavilion 11 x360 Battery Replacement: étape 7, image 1 de 2 HP Pavilion 11 x360 Battery Replacement: étape 7, image 2 de 2
    • Remove the battery.
27 autres ont terminé cette réparation.
Natalie
Membre depuis le 01/22/15
937 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 19-9, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 19-9, Maness Winter 2015
CPSU-MANESS-W15S19G9
4 membres
12 tutoriels rédigés
11 commentaires
exellent and easy steps............but......where do i buy battery.....?
Akshay R Manohar - Réponse
Muy bueno parece facil
mejiawilson - Réponse
Great step by step explanation. Solid pictures!!! Could not have fixed this without your contribution!!!
Joe Consumidor - Réponse
Purchased this laptop 28/12/2015 and now its just not switching on at all. I will try the repair instructions but I think it should have lasted a bit longer, what ever the problem is. The store where I bought it have checked the cable for me to see if that was the problem and it wasn’t. They wanted £60 to send it off, to find out the issue before anything was even done. The sales assistant said it could be the battery but he said it should have lasted longer. He basically said if its the motherboard you may as well just throw it out. I am sick of paying £100’s out for electrical items that live very short lives. My daughter bought this with her own money that she had been saving. I would not purchase this make of laptop again and where do I get a replacement battery and how much is that likely to be?
jane coombes - Réponse
Very good guide, thank you!
FanMac - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 28
30 derniers jours : 50
Total : 59,784
