Aller au contenu principal
HP Pavilion 11 x360 Fan Replacement
Ce dont vous avez besoin
  1. HP Pavilion 11 x360 Fan Replacement, Remove Screws: étape 1, image 1 de 2 HP Pavilion 11 x360 Fan Replacement, Remove Screws: étape 1, image 2 de 2
    • Use the spudger to pry off the two rubber feet near the hinge of the laptop. This will reveal two hidden 9mm screws.
    • You must remove eleven screws.
    • Four 9mm screws with the PH0 screwdriver.
    • Seven 6mm screws with the PH0 screwdriver.
  2. HP Pavilion 11 x360 Fan Replacement, Remove Backing: étape 2, image 1 de 3 HP Pavilion 11 x360 Fan Replacement, Remove Backing: étape 2, image 2 de 3 HP Pavilion 11 x360 Fan Replacement, Remove Backing: étape 2, image 3 de 3
    • Use the spudger to pry the corners of the laptop near the display hinges.
    • Pry around the seam of the laptop with the plastic opening tool until the backing begins to pull apart.
    • When you lift the bottom cover, there is a cable connected between the motherboard and the bottom cover. Be careful not to pull the cable loose!
  3. HP Pavilion 11 x360 Fan Replacement, Detach Cable: étape 3, image 1 de 2 HP Pavilion 11 x360 Fan Replacement, Detach Cable: étape 3, image 2 de 2
    • Use the plastic opening tool to lift the white tab up at the connection.
    • Pull the cable outwards.
  4. HP Pavilion 11 x360 Fan Replacement, Remove Screws: étape 4, image 1 de 1
    • Remove the two 3mm screws with the PH0 screwdriver.
  5. HP Pavilion 11 x360 Fan Replacement, Disconnect Cable: étape 5, image 1 de 2 HP Pavilion 11 x360 Fan Replacement, Disconnect Cable: étape 5, image 2 de 2
    • Use your fingernails to slowly loosen the fan connection cable.
    • After the cable is slightly pulled from the connection, grab the cable and pull it outwards.
6 autres ont terminé cette réparation.
Natalie
Membre depuis le 01/22/15
937 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 19-9, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 19-9, Maness Winter 2015
CPSU-MANESS-W15S19G9
4 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 25
Total : 2,620
