Introduction
This guide will instruct a user on how to remove the fan in order to replace a potentially faulty piece of hardware. Be sure the device is turned off and disconnected from all power sources.
Ce dont vous avez besoin
Use the nylon spudger to remove the rubber pads near the hinge of the screen, then remove the screws under the pads.
Use the Phillips #0 to remove four 9mm screws.
Use the Phillips #0 to remove seven 6mm screws.
2 autres ont terminé cette réparation.
