Aller au contenu principal
HP Pavilion 13-s128nr Back Panel Replacement
Ce dont vous avez besoin
  1. HP Pavilion 13-s128nr Back Panel Replacement, Back Panel: étape 1, image 1 de 2 HP Pavilion 13-s128nr Back Panel Replacement, Back Panel: étape 1, image 2 de 2
    • Use the iFixit opening tool to take off the rubber caps.
    • Remove the screws using the Phillips #0 screwdriver.
  2. HP Pavilion 13-s128nr Back Panel Replacement: étape 2, image 1 de 1
    • Use the Jimmy to pry around the seam of the laptop.
    • Remove the back panel of the laptop.
    • Don't completely remove the back panel as there are ribbon cables that can be easily damaged if removed quickly.
  3. HP Pavilion 13-s128nr Back Panel Replacement: étape 3, image 1 de 2 HP Pavilion 13-s128nr Back Panel Replacement: étape 3, image 2 de 2
    • Using the iFixit opening tool to lift the tabs holding in the cables connecting the keyboard to the motherboard.
    • Pull the cable from the motherboard.
Sydney Bell
Membre depuis le 02/13/20
317 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 19
Total : 799
