Introduction
Solid state drives contain no moving parts, unlike a hard drive, and can last for years. One might want to switch from a hard drive to a SSD or purchase a bigger storage SSD. This guide will walk you through replacing the SSD card inside the motherboard.
Ce dont vous avez besoin
Turn the laptop over.
Remove all nine 3mm screws on back panel with a Phillips Head 1 driver.
While keeping silver keyboard panel hovering above the laptop, locate the touchpad connector ribbon attached to both the silver panel and motherboard.
With your finger, flip up the white clasp that holds the connector, releasing the connector ribbon.
Unpeel the connector ribbon from its position on the motherboard.
With the internal hardware exposed, disconnect the battery cable from the motherboard.
If tightly fastened, gently wiggle the plug out of the jack.
Remove the two Wi-Fi antenna cables that are attached to the Wi-Fi card by pulling them up.
Remove the 3mm screw located directly above the NGFF SSD card using a Phillips Head 1 driver.
2 autres ont terminé cette réparation.
