Introduction
In this guide, you will find useful information on replacing the cooling fan for an HP Pavilion 14-b015dx laptop.
If your laptop fan is operating loudly or makes abnormal noises, then there is a chance it is damaged and needs to be replaced. Additionally, the temperature of the CPU and GPU of the laptop will be higher than normal, which can lead to reduced performance.
This guide requires the removal of the keyboard and top case of the laptop. Before starting this process, the laptop must be unplugged and powered off completely.
Ce dont vous avez besoin
Unscrew the ten 6.0 mm Philips head screws on the base of the device with a Phillips #0 head screwdriver.
Remove the eight 6.0 mm screws located under the keyboard with your Philips #0 screwdriver.
Your now ready to remove the cooling fan.
Disconnect the cable that connects the fan to the motherboard.
