Aller au contenu principal
HP Pavilion 14-b015dx Wireless Card Replacement
Ce dont vous avez besoin
  1. HP Pavilion 14-b015dx Wireless Card Replacement, Battery: étape 1, image 1 de 1
    • Make sure the computer is completely powered down and unplug the power cord.
  2. HP Pavilion 14-b015dx Wireless Card Replacement: étape 2, image 1 de 1
    • Place the device on your work surface with bottom facing up and the battery located at the top.
  3. HP Pavilion 14-b015dx Wireless Card Replacement: étape 3, image 1 de 1
    • Slide the left release tab toward the center of the computer to the unlock position. Next slid the right tab toward the center of the computer and hold it there while completing step 4.
  4. HP Pavilion 14-b015dx Wireless Card Replacement: étape 4, image 1 de 1
    • Remove the battery by sliding it upwards and away from the computer.
  5. HP Pavilion 14-b015dx Wireless Card Replacement, Keyboard: étape 5, image 1 de 1
    • Unscrew the ten 6.0 mm Philips head screws on the base of the device with a Phillips #0 head screwdriver.
  6. HP Pavilion 14-b015dx Wireless Card Replacement: étape 6, image 1 de 1
    • Insert the plastic opening tool between the keyboard and the plastic housing.
    • Pry the keyboard upward away from the device.
    • Move the tool around the edge of the entire keyboard while continuing to pry.
    • You will hear the clips pop once you have released them.
  7. HP Pavilion 14-b015dx Wireless Card Replacement: étape 7, image 1 de 1
    • Once you have released all of the clips, slowly lift the keyboard exposing the ribbon cable.
    • Lift the tab on the keyboard ZIF connector with a plastic opening tool and gently remove the ribbon cable.
  8. HP Pavilion 14-b015dx Wireless Card Replacement, Palm Rest: étape 8, image 1 de 1
    • Remove the eight 6.0 mm screws located under the keyboard with your Philips #0 screwdriver.
  9. HP Pavilion 14-b015dx Wireless Card Replacement: étape 9, image 1 de 1
    • Remove the track pad and power button ribbon cables.
    • Lift the locking bar on each connector with a plastic opening tool and gently remove the ribbon cables
  10. HP Pavilion 14-b015dx Wireless Card Replacement: étape 10, image 1 de 1
    • To remove the palm rest, insert the plastic opening tool in the seam between the palm rest and the base.
    • Pry upward to undo each clip.
    • Continue this process around the entire palm rest.
  11. HP Pavilion 14-b015dx Wireless Card Replacement: étape 11, image 1 de 1
    • Once all clips have been undone lift the palm rest away from the laptop.
  12. HP Pavilion 14-b015dx Wireless Card Replacement, Wireless Card: étape 12, image 1 de 1
    • Remove the two 4.0 mm long screws on the corners of the wireless card the using a Philips #0 screwdriver.
  13. HP Pavilion 14-b015dx Wireless Card Replacement: étape 13, image 1 de 1
    • Remove the black and white wires attached to the wireless card by using your blue opening tool and prying upward.
  14. HP Pavilion 14-b015dx Wireless Card Replacement: étape 14, image 1 de 1
    • Once you have removed the screws and wires on the network card lift it up and away from the motherboard.
Gregory Bridge
Membre depuis le 10/24/17
623 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G1, Isaacson Fall 2017 Membre de l'équipe UMass Dartmouth, Team S1-G1, Isaacson Fall 2017
UMASSD-ISAACSON-F17S1G1
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 288
