Aller au contenu principal
HP Pavilion 14-b120dx Keyboard Replacement
Ce dont vous avez besoin
  1. HP Pavilion 14-b120dx Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Power down the laptop and detach the charging cord (failure to do so can result in electrical shock).
  2. HP Pavilion 14-b120dx Keyboard Replacement: étape 2, image 1 de 3 HP Pavilion 14-b120dx Keyboard Replacement: étape 2, image 2 de 3 HP Pavilion 14-b120dx Keyboard Replacement: étape 2, image 3 de 3
    • Flip the laptop upside down so that the bottom is facing you.
    • Push the slide on the right toward the center of the laptop, releasing the battery latch.
    • Lift the battery up and away from the laptop.
  3. HP Pavilion 14-b120dx Keyboard Replacement, Keyboard: étape 3, image 1 de 3 HP Pavilion 14-b120dx Keyboard Replacement, Keyboard: étape 3, image 2 de 3 HP Pavilion 14-b120dx Keyboard Replacement, Keyboard: étape 3, image 3 de 3
    • Insert the plastic opening tool between the keyboard and the palm rest.
    • Pry upwards until the keyboard section detaches from the laptop.
    • Repeat this around the edge of the entire keyboard.
    • Sections will make loud snapping noises as they detach from the palm rest - this is normal.
  4. HP Pavilion 14-b120dx Keyboard Replacement: étape 4, image 1 de 2 HP Pavilion 14-b120dx Keyboard Replacement: étape 4, image 2 de 2
    • Lift the keyboard slowly up until the connecting cable is exposed.
    • Carefully lift the flap on the ZIF connector using a fingernail or plastic opening tool. This will release the cable.
    • Detach the cable.
Joshua Carberry
Membre depuis le 10/20/16
240 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-4, Catania Fall 2016 Membre de l'équipe UMass Dartmouth, Team 4-4, Catania Fall 2016
UMASSD-CATANIA-F16S4G4
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 22
Total : 964
