Introduction
This guide will show you how to replace the keyboard on your HP Pavilion 14-v062us.
Pièces
Aucune pièce spécifiée.
Push inward towards the center of laptop (it may take a lot of pressure). Battery should release once buttons are completely pushed in
Remove rectangular rubber tops with a spudger
Remove the two 4.60 mm PH#1 screws located under rectangular rubber tops.
Remove plastic edge covering with the blue plastic opening tool.
Remove two 4.63 mm PH#1 screws located under plastic edge covering.
2 autre(s) ont terminé cette réparation.
2 commentaires
Thank you so much, this guide is very helpful.
