Aller au contenu principal
HP Pavilion 15-ab165us Motherboard Replacement
Ce dont vous avez besoin
  1. HP Pavilion 15-ab165us Motherboard Replacement, Battery and Back Cover: étape 1, image 1 de 2 HP Pavilion 15-ab165us Motherboard Replacement, Battery and Back Cover: étape 1, image 2 de 2
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us Motherboard Replacement: étape 2, image 1 de 3 HP Pavilion 15-ab165us Motherboard Replacement: étape 2, image 2 de 3 HP Pavilion 15-ab165us Motherboard Replacement: étape 2, image 3 de 3
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us Motherboard Replacement: étape 3, image 1 de 3 HP Pavilion 15-ab165us Motherboard Replacement: étape 3, image 2 de 3 HP Pavilion 15-ab165us Motherboard Replacement: étape 3, image 3 de 3
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us Motherboard Replacement: étape 4, image 1 de 1
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us Motherboard Replacement: étape 5, image 1 de 1
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us Motherboard Replacement: étape 6, image 1 de 1
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us Motherboard Replacement: étape 7, image 1 de 2 HP Pavilion 15-ab165us Motherboard Replacement: étape 7, image 2 de 2
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us Motherboard Replacement: étape 8, image 1 de 1
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
  9. HP Pavilion 15-ab165us Motherboard Replacement, Motherboard: étape 9, image 1 de 1
    • Locate the motherboard.
  10. HP Pavilion 15-ab165us Motherboard Replacement: étape 10, image 1 de 2 HP Pavilion 15-ab165us Motherboard Replacement: étape 10, image 2 de 2
    • Disconnect the wire connected to the Wifi card.
  11. HP Pavilion 15-ab165us Motherboard Replacement: étape 11, image 1 de 1
    • Disconnect the speakers.
  12. HP Pavilion 15-ab165us Motherboard Replacement: étape 12, image 1 de 3 HP Pavilion 15-ab165us Motherboard Replacement: étape 12, image 2 de 3 HP Pavilion 15-ab165us Motherboard Replacement: étape 12, image 3 de 3
    • Unlock and disconnect cables attached to the motherboard that connect to the display.
  13. HP Pavilion 15-ab165us Motherboard Replacement: étape 13, image 1 de 2 HP Pavilion 15-ab165us Motherboard Replacement: étape 13, image 2 de 2
    • Unlock and remove the cable connected to the optical drive.
  14. HP Pavilion 15-ab165us Motherboard Replacement: étape 14, image 1 de 2 HP Pavilion 15-ab165us Motherboard Replacement: étape 14, image 2 de 2
    • Unlock and remove the cable that connects to the hard drive.
  15. HP Pavilion 15-ab165us Motherboard Replacement: étape 15, image 1 de 3 HP Pavilion 15-ab165us Motherboard Replacement: étape 15, image 2 de 3 HP Pavilion 15-ab165us Motherboard Replacement: étape 15, image 3 de 3
    • Unlock and remove the cables connected to the keyboard.
  16. HP Pavilion 15-ab165us Motherboard Replacement: étape 16, image 1 de 1
    • Remove the 4mm screws holding the motherboard in place with a Phillips #1 screwdriver.
  17. HP Pavilion 15-ab165us Motherboard Replacement: étape 17, image 1 de 1
  18. HP Pavilion 15-ab165us Motherboard Replacement: étape 18, image 1 de 2 HP Pavilion 15-ab165us Motherboard Replacement: étape 18, image 2 de 2
    • Disconnect the fan pins.
    • Lift up to remove the fan.
  19. HP Pavilion 15-ab165us Motherboard Replacement: étape 19, image 1 de 1
    • Release motherboard from the clip at the base of the hard drive.
  20. HP Pavilion 15-ab165us Motherboard Replacement: étape 20, image 1 de 2 HP Pavilion 15-ab165us Motherboard Replacement: étape 20, image 2 de 2
    • Lift the motherboard up and flip it around to reveal the cable connected on the underside.
  21. HP Pavilion 15-ab165us Motherboard Replacement: étape 21, image 1 de 2 HP Pavilion 15-ab165us Motherboard Replacement: étape 21, image 2 de 2
    • Unlock and disconnect the cable connected to the underside of the motherboard.
    • Pull the motherboard out of the chassis.
3 autres ont terminé cette réparation.
Dillon Hubble
Membre depuis le 10/20/17
653 Réputation
3 tutoriels rédigés
Équipe
UW Tacoma, Team S1-G2, Rose Fall 2017 Membre de l'équipe UW Tacoma, Team S1-G2, Rose Fall 2017
UWT-ROSE-F17S1G2
5 membres
14 tutoriels rédigés
0 Guide Comments
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 27
Total : 1,598
