Aller au contenu principal
HP Pavilion 15-ab165us RAM Replacement
Ce dont vous avez besoin
  1. HP Pavilion 15-ab165us RAM Replacement, Battery and Back Cover: étape 1, image 1 de 2 HP Pavilion 15-ab165us RAM Replacement, Battery and Back Cover: étape 1, image 2 de 2
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us RAM Replacement: étape 2, image 1 de 3 HP Pavilion 15-ab165us RAM Replacement: étape 2, image 2 de 3 HP Pavilion 15-ab165us RAM Replacement: étape 2, image 3 de 3
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us RAM Replacement: étape 3, image 1 de 3 HP Pavilion 15-ab165us RAM Replacement: étape 3, image 2 de 3 HP Pavilion 15-ab165us RAM Replacement: étape 3, image 3 de 3
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us RAM Replacement: étape 4, image 1 de 1
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us RAM Replacement: étape 5, image 1 de 1
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us RAM Replacement: étape 6, image 1 de 1
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us RAM Replacement: étape 7, image 1 de 2 HP Pavilion 15-ab165us RAM Replacement: étape 7, image 2 de 2
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us RAM Replacement: étape 8, image 1 de 1
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
  9. HP Pavilion 15-ab165us RAM Replacement, RAM: étape 9, image 1 de 1
    • Locate RAM.
  10. HP Pavilion 15-ab165us RAM Replacement: étape 10, image 1 de 1
    • Pull the tension arms away from both sides the RAM.
  11. HP Pavilion 15-ab165us RAM Replacement: étape 11, image 1 de 1
    • Pull RAM away from the RAM slot.
  12. HP Pavilion 15-ab165us RAM Replacement: étape 12, image 1 de 1
    • Repeat this process for the next stick of RAM.
3 autres ont terminé cette réparation.
Myai Nguyen
Membre depuis le 10/20/17
203 Réputation
1 tutoriel rédigé
Équipe
UW Tacoma, Team S1-G2, Rose Fall 2017 Membre de l'équipe UW Tacoma, Team S1-G2, Rose Fall 2017
UWT-ROSE-F17S1G2
5 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 34
Total : 2,395
