Aller au contenu principal
HP Pavilion 15-ab243cl CMOS Battery Replacement
Ce dont vous avez besoin
  1. HP Pavilion 15-ab243cl CMOS Battery Replacement, Battery: étape 1, image 1 de 2 HP Pavilion 15-ab243cl CMOS Battery Replacement, Battery: étape 1, image 2 de 2
    • Slide the battery lock tab toward the center of the battery to the unlock position.
  2. HP Pavilion 15-ab243cl CMOS Battery Replacement: étape 2, image 1 de 3 HP Pavilion 15-ab243cl CMOS Battery Replacement: étape 2, image 2 de 3 HP Pavilion 15-ab243cl CMOS Battery Replacement: étape 2, image 3 de 3
    • Slide the battery release switch to the right until the battery pops out.
  3. HP Pavilion 15-ab243cl CMOS Battery Replacement: étape 3, image 1 de 2 HP Pavilion 15-ab243cl CMOS Battery Replacement: étape 3, image 2 de 2
    • Grabbing the top edge of the battery, rotate it toward you and then lift upward to relieve the battery from its slot.
  4. HP Pavilion 15-ab243cl CMOS Battery Replacement, Laptop Case: étape 4, image 1 de 3 HP Pavilion 15-ab243cl CMOS Battery Replacement, Laptop Case: étape 4, image 2 de 3 HP Pavilion 15-ab243cl CMOS Battery Replacement, Laptop Case: étape 4, image 3 de 3
    • With the battery removed, remove both black plastic covers with a plastic opening tool. Unscrew both 7.5 mm screws from the tabs, using a PH1 screw driver. Using a plastic opening tool, pry off both covers.
  5. HP Pavilion 15-ab243cl CMOS Battery Replacement: étape 5, image 1 de 3 HP Pavilion 15-ab243cl CMOS Battery Replacement: étape 5, image 2 de 3 HP Pavilion 15-ab243cl CMOS Battery Replacement: étape 5, image 3 de 3
    • Remove all 16 of the 3.5 mm screws with a PH1 screwdriver and pry/slide the CD drive out of laptop.
  6. HP Pavilion 15-ab243cl CMOS Battery Replacement: étape 6, image 1 de 2 HP Pavilion 15-ab243cl CMOS Battery Replacement: étape 6, image 2 de 2
    • With the CD drive removed, unscrew the two 2mm silver screws with a PH00.
    • These can strip easily, so take your time removing.
  7. HP Pavilion 15-ab243cl CMOS Battery Replacement: étape 7, image 1 de 3 HP Pavilion 15-ab243cl CMOS Battery Replacement: étape 7, image 2 de 3 HP Pavilion 15-ab243cl CMOS Battery Replacement: étape 7, image 3 de 3
    • Using a plastic opening tool, begin to pry edge of case away from the laptop. Work around the edges until all sides, except back, are open.
  8. HP Pavilion 15-ab243cl CMOS Battery Replacement: étape 8, image 1 de 3 HP Pavilion 15-ab243cl CMOS Battery Replacement: étape 8, image 2 de 3 HP Pavilion 15-ab243cl CMOS Battery Replacement: étape 8, image 3 de 3
    • On the back side of the laptop, where the battery is, there are 12 black plastic clips. Use a plastic opening tool and pry all of these clips, unlatching them from the case.
    • Once clips are free, open the laptop. Rotating the case off, around the hinges, works best to remove the case.
  9. HP Pavilion 15-ab243cl CMOS Battery Replacement, CMOS Battery: étape 9, image 1 de 2 HP Pavilion 15-ab243cl CMOS Battery Replacement, CMOS Battery: étape 9, image 2 de 2
    • Use long nose tweezers to reach under battery and lift up.
  10. HP Pavilion 15-ab243cl CMOS Battery Replacement: étape 10, image 1 de 2 HP Pavilion 15-ab243cl CMOS Battery Replacement: étape 10, image 2 de 2
    • Lift up until battery pops out, remove battery
Alexander Bicigo
Membre depuis le 02/14/18
942 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S6-G3, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S6-G3, Eyestone Spring 2018
USFT-EYESTONE-S18S6G3
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 23
Total : 1,213
