Aller au contenu principal
HP Pavilion 15-au123cl CD Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion 15-au123cl CD Drive Replacement, Battery: étape 1, image 1 de 1
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl CD Drive Replacement: étape 2, image 1 de 2 HP Pavilion 15-au123cl CD Drive Replacement: étape 2, image 2 de 2
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. HP Pavilion 15-au123cl CD Drive Replacement: étape 3, image 1 de 2 HP Pavilion 15-au123cl CD Drive Replacement: étape 3, image 2 de 2
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. HP Pavilion 15-au123cl CD Drive Replacement: étape 4, image 1 de 2 HP Pavilion 15-au123cl CD Drive Replacement: étape 4, image 2 de 2
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  5. HP Pavilion 15-au123cl CD Drive Replacement: étape 5, image 1 de 3 HP Pavilion 15-au123cl CD Drive Replacement: étape 5, image 2 de 3 HP Pavilion 15-au123cl CD Drive Replacement: étape 5, image 3 de 3
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl CD Drive Replacement, CD Drive: étape 6, image 1 de 1
    • The CD Drive is located at the bottom right area of the motherboard.
  7. HP Pavilion 15-au123cl CD Drive Replacement: étape 7, image 1 de 2 HP Pavilion 15-au123cl CD Drive Replacement: étape 7, image 2 de 2
    • Disconnect the CD drive from the motherboard connector on the left.
Mohammad Gardezi
Membre depuis le 10/17/17
1 420 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S13-G3, Cagle Fall 2017 Membre de l'équipe USF Tampa, Team S13-G3, Cagle Fall 2017
USFT-CAGLE-F17S13G3
2 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 12
Total : 560
