Aller au contenu principal
HP Pavilion 15-au123cl Motherboard Replacement
Ce dont vous avez besoin
  1. HP Pavilion 15-au123cl Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl Motherboard Replacement: étape 2, image 1 de 2 HP Pavilion 15-au123cl Motherboard Replacement: étape 2, image 2 de 2
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. HP Pavilion 15-au123cl Motherboard Replacement: étape 3, image 1 de 2 HP Pavilion 15-au123cl Motherboard Replacement: étape 3, image 2 de 2
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. HP Pavilion 15-au123cl Motherboard Replacement: étape 4, image 1 de 2 HP Pavilion 15-au123cl Motherboard Replacement: étape 4, image 2 de 2
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  5. HP Pavilion 15-au123cl Motherboard Replacement: étape 5, image 1 de 3 HP Pavilion 15-au123cl Motherboard Replacement: étape 5, image 2 de 3 HP Pavilion 15-au123cl Motherboard Replacement: étape 5, image 3 de 3
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl Motherboard Replacement, Network Card: étape 6, image 1 de 3 HP Pavilion 15-au123cl Motherboard Replacement, Network Card: étape 6, image 2 de 3 HP Pavilion 15-au123cl Motherboard Replacement, Network Card: étape 6, image 3 de 3
    • The network card is located at the top left corner of the motherboard.
    • Unscrew the 4.4mm PH0 Phillips screw at the top of the network card.
  7. HP Pavilion 15-au123cl Motherboard Replacement: étape 7, image 1 de 3 HP Pavilion 15-au123cl Motherboard Replacement: étape 7, image 2 de 3 HP Pavilion 15-au123cl Motherboard Replacement: étape 7, image 3 de 3
    • Using the spudger, remove the two gold pins at the top of the network card.
    • It is recommended to gently apply a vertical force upward with the spudger.
  8. HP Pavilion 15-au123cl Motherboard Replacement: étape 8, image 1 de 3 HP Pavilion 15-au123cl Motherboard Replacement: étape 8, image 2 de 3 HP Pavilion 15-au123cl Motherboard Replacement: étape 8, image 3 de 3
    • Lift up the network card and remove it from the motherboard connector.
  9. HP Pavilion 15-au123cl Motherboard Replacement, Motherboard: étape 9, image 1 de 1
    • Firmly disconnect the fan from the motherboard.
    • Remove the three screws from the fan using a Philips #0 Screwdriver.
  10. HP Pavilion 15-au123cl Motherboard Replacement: étape 10, image 1 de 1
    • Remove the six screws from the motherboard using a Philips #0 Screwdriver.
  11. HP Pavilion 15-au123cl Motherboard Replacement: étape 11, image 1 de 1
    • Disconnect the ribbon cables from the motherboard.
    • Remove the motherboard.
3 autres ont terminé cette réparation.
Un commentaire
buenas tardes : Nesecito saber donde puedo conseguir el Motherboard para una HP Pavilion Y1N95UA 15-AU123CL descrito en este posteo ..
Saludos Gabriel Angel..!!!
Gabriel Antonielli - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 21
Total : 1,789
