Aller au contenu principal
HP Pavilion 15-au123cl Network Card Replacement
Ce dont vous avez besoin
  1. HP Pavilion 15-au123cl Network Card Replacement, Battery: étape 1, image 1 de 1
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl Network Card Replacement: étape 2, image 1 de 2 HP Pavilion 15-au123cl Network Card Replacement: étape 2, image 2 de 2
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. HP Pavilion 15-au123cl Network Card Replacement: étape 3, image 1 de 2 HP Pavilion 15-au123cl Network Card Replacement: étape 3, image 2 de 2
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. HP Pavilion 15-au123cl Network Card Replacement: étape 4, image 1 de 2 HP Pavilion 15-au123cl Network Card Replacement: étape 4, image 2 de 2
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  5. HP Pavilion 15-au123cl Network Card Replacement: étape 5, image 1 de 3 HP Pavilion 15-au123cl Network Card Replacement: étape 5, image 2 de 3 HP Pavilion 15-au123cl Network Card Replacement: étape 5, image 3 de 3
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl Network Card Replacement, Network Card: étape 6, image 1 de 3 HP Pavilion 15-au123cl Network Card Replacement, Network Card: étape 6, image 2 de 3 HP Pavilion 15-au123cl Network Card Replacement, Network Card: étape 6, image 3 de 3
    • The network card is located at the top left corner of the motherboard.
    • Unscrew the 4.4mm PH0 Phillips screw at the top of the network card.
  7. HP Pavilion 15-au123cl Network Card Replacement: étape 7, image 1 de 3 HP Pavilion 15-au123cl Network Card Replacement: étape 7, image 2 de 3 HP Pavilion 15-au123cl Network Card Replacement: étape 7, image 3 de 3
    • Using the spudger, remove the two gold pins at the top of the network card.
    • It is recommended to gently apply a vertical force upward with the spudger.
  8. HP Pavilion 15-au123cl Network Card Replacement: étape 8, image 1 de 3 HP Pavilion 15-au123cl Network Card Replacement: étape 8, image 2 de 3 HP Pavilion 15-au123cl Network Card Replacement: étape 8, image 3 de 3
    • Lift up the network card and remove it from the motherboard connector.
Mohammad Gardezi
Membre depuis le 10/17/17
1 420 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S13-G3, Cagle Fall 2017 Membre de l'équipe USF Tampa, Team S13-G3, Cagle Fall 2017
USFT-CAGLE-F17S13G3
2 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 16
Total : 1,492
