Aller au contenu principal
HP Pavilion 15-b109wm Keyboard Replacement
Ce dont vous avez besoin
  1. HP Pavilion 15-b109wm Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Power off the device and disconnect from any power source.
  2. HP Pavilion 15-b109wm Keyboard Replacement: étape 2, image 1 de 1
    • Turn the device upside down and ensure the back of the device is facing you.
  3. HP Pavilion 15-b109wm Keyboard Replacement: étape 3, image 1 de 3 HP Pavilion 15-b109wm Keyboard Replacement: étape 3, image 2 de 3 HP Pavilion 15-b109wm Keyboard Replacement: étape 3, image 3 de 3
    • Push both buttons towards one another simultaneously. The battery slightly pops out.
  4. HP Pavilion 15-b109wm Keyboard Replacement: étape 4, image 1 de 3 HP Pavilion 15-b109wm Keyboard Replacement: étape 4, image 2 de 3 HP Pavilion 15-b109wm Keyboard Replacement: étape 4, image 3 de 3
    • Pull out the battery from the device's battery slot.
  5. HP Pavilion 15-b109wm Keyboard Replacement, Keyboard: étape 5, image 1 de 2 HP Pavilion 15-b109wm Keyboard Replacement, Keyboard: étape 5, image 2 de 2
    • Use JIS #1 screwdriver to remove the eleven 6 mm screws.
  6. HP Pavilion 15-b109wm Keyboard Replacement: étape 6, image 1 de 1
    • Locate the two screw holes that allow access to removing the keyboard.
    • There is a keyboard sign beside both keyboard access holes.
  7. HP Pavilion 15-b109wm Keyboard Replacement: étape 7, image 1 de 1
    • Turn the device onto its side.
    • Using a heavy duty spudger, gently disengage the keyboard.
  8. HP Pavilion 15-b109wm Keyboard Replacement: étape 8, image 1 de 2 HP Pavilion 15-b109wm Keyboard Replacement: étape 8, image 2 de 2
    • Using a plastic opening tool, release the keyboard clips.
  9. HP Pavilion 15-b109wm Keyboard Replacement: étape 9, image 1 de 1
    • Tilt the keyboard to expose the Zero Insertion Force connector to which the keyboard cable is attached.
  10. HP Pavilion 15-b109wm Keyboard Replacement: étape 10, image 1 de 3 HP Pavilion 15-b109wm Keyboard Replacement: étape 10, image 2 de 3 HP Pavilion 15-b109wm Keyboard Replacement: étape 10, image 3 de 3
    • Disconnect the keyboard cable from the motherboard by detaching the Zero Insertion Force connector.
    • To detach the connector, release by lifting the black plastic tab up.
David Atunlute
Membre depuis le 10/30/18
241 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G2, Peak Fall 2018 Membre de l'équipe UMass Dartmouth, Team S2-G2, Peak Fall 2018
UMASSD-PEAK-F18S2G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 8
Total : 475
