Aller au contenu principal
HP Pavilion 15-b109wm RAM Replacement
Ce dont vous avez besoin
  1. HP Pavilion 15-b109wm RAM Replacement, Battery: étape 1, image 1 de 1
    • Power off the device and disconnect from any power source.
  2. HP Pavilion 15-b109wm RAM Replacement: étape 2, image 1 de 1
    • Turn the device upside down and ensure the back of the device is facing you.
  3. HP Pavilion 15-b109wm RAM Replacement: étape 3, image 1 de 3 HP Pavilion 15-b109wm RAM Replacement: étape 3, image 2 de 3 HP Pavilion 15-b109wm RAM Replacement: étape 3, image 3 de 3
    • Push both buttons towards one another simultaneously. The battery slightly pops out.
  4. HP Pavilion 15-b109wm RAM Replacement: étape 4, image 1 de 3 HP Pavilion 15-b109wm RAM Replacement: étape 4, image 2 de 3 HP Pavilion 15-b109wm RAM Replacement: étape 4, image 3 de 3
    • Pull out the battery from the device's battery slot.
  5. HP Pavilion 15-b109wm RAM Replacement, Keyboard: étape 5, image 1 de 2 HP Pavilion 15-b109wm RAM Replacement, Keyboard: étape 5, image 2 de 2
    • Use JIS #1 screwdriver to remove the eleven 6 mm screws.
  6. HP Pavilion 15-b109wm RAM Replacement: étape 6, image 1 de 1
    • Locate the two screw holes that allow access to removing the keyboard.
    • There is a keyboard sign beside both keyboard access holes.
  7. HP Pavilion 15-b109wm RAM Replacement: étape 7, image 1 de 1
    • Turn the device onto its side.
    • Using a heavy duty spudger, gently disengage the keyboard.
  8. HP Pavilion 15-b109wm RAM Replacement: étape 8, image 1 de 2 HP Pavilion 15-b109wm RAM Replacement: étape 8, image 2 de 2
    • Using a plastic opening tool, release the keyboard clips.
  9. HP Pavilion 15-b109wm RAM Replacement: étape 9, image 1 de 1
    • Tilt the keyboard to expose the Zero Insertion Force connector to which the keyboard cable is attached.
  10. HP Pavilion 15-b109wm RAM Replacement: étape 10, image 1 de 3 HP Pavilion 15-b109wm RAM Replacement: étape 10, image 2 de 3 HP Pavilion 15-b109wm RAM Replacement: étape 10, image 3 de 3
    • Disconnect the keyboard cable from the motherboard by detaching the Zero Insertion Force connector.
    • To detach the connector, release by lifting the black plastic tab up.
  11. HP Pavilion 15-b109wm RAM Replacement, Fan: étape 11, image 1 de 3 HP Pavilion 15-b109wm RAM Replacement, Fan: étape 11, image 2 de 3 HP Pavilion 15-b109wm RAM Replacement, Fan: étape 11, image 3 de 3
    • Using a JIS #1 screwdriver, remove the five 5mm screws.
    • Detach the power button cable.
    • Detach the touch pad cable.
  12. HP Pavilion 15-b109wm RAM Replacement: étape 12, image 1 de 3 HP Pavilion 15-b109wm RAM Replacement: étape 12, image 2 de 3 HP Pavilion 15-b109wm RAM Replacement: étape 12, image 3 de 3
    • Using a plastic opening tool, pry open the top cover.
    • Unscrew the two 5 mm screws using a JIS #1 screwdriver.
    • Gently, pull to detach the fan cable.
    • Be careful so you do not damage the motherboard.
  13. HP Pavilion 15-b109wm RAM Replacement: étape 13, image 1 de 1
    • Carefully remove the fan from its slot.
  14. HP Pavilion 15-b109wm RAM Replacement, RAM: étape 14, image 1 de 3 HP Pavilion 15-b109wm RAM Replacement, RAM: étape 14, image 2 de 3 HP Pavilion 15-b109wm RAM Replacement, RAM: étape 14, image 3 de 3
    • Disconnect the cables to the motherboard.
  15. HP Pavilion 15-b109wm RAM Replacement: étape 15, image 1 de 2 HP Pavilion 15-b109wm RAM Replacement: étape 15, image 2 de 2
    • Remove the eight 5 mm screws with the JIS #1 screwdriver.
  16. HP Pavilion 15-b109wm RAM Replacement: étape 16, image 1 de 2 HP Pavilion 15-b109wm RAM Replacement: étape 16, image 2 de 2
    • Remove the hard drive.
  17. HP Pavilion 15-b109wm RAM Replacement: étape 17, image 1 de 1
    • Unclip the WLAN cable out of its place to allow the motherboard room to move.
  18. HP Pavilion 15-b109wm RAM Replacement: étape 18, image 1 de 1
    • Detach the power connector cable.
  19. HP Pavilion 15-b109wm RAM Replacement: étape 19, image 1 de 2 HP Pavilion 15-b109wm RAM Replacement: étape 19, image 2 de 2
    • Lift up the motherboard from the bottom side of the device.
  20. HP Pavilion 15-b109wm RAM Replacement: étape 20, image 1 de 3 HP Pavilion 15-b109wm RAM Replacement: étape 20, image 2 de 3 HP Pavilion 15-b109wm RAM Replacement: étape 20, image 3 de 3
    • Using your thumbs, push out on the bracket.
    • When the memory module feels loose, pull up on the module.
Stephen Gacioch
Membre depuis le 10/26/18
437 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G2, Peak Fall 2018 Membre de l'équipe UMass Dartmouth, Team S2-G2, Peak Fall 2018
UMASSD-PEAK-F18S2G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 10
Total : 666
