Aller au contenu principal
HP Pavilion 15-ba003ds Charging Port Replacement
Ce dont vous avez besoin
  1. HP Pavilion 15-ba003ds Charging Port Replacement, Battery: étape 1, image 1 de 2 HP Pavilion 15-ba003ds Charging Port Replacement, Battery: étape 1, image 2 de 2
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds Charging Port Replacement, Backplate: étape 2, image 1 de 3 HP Pavilion 15-ba003ds Charging Port Replacement, Backplate: étape 2, image 2 de 3 HP Pavilion 15-ba003ds Charging Port Replacement, Backplate: étape 2, image 3 de 3
    • Use a Jimmy to pry off the black backplate.
  3. HP Pavilion 15-ba003ds Charging Port Replacement, Cooling Fan: étape 3, image 1 de 2 HP Pavilion 15-ba003ds Charging Port Replacement, Cooling Fan: étape 3, image 2 de 2
    • Remove three black 6mm Phillips #00 screws.
  4. HP Pavilion 15-ba003ds Charging Port Replacement: étape 4, image 1 de 3 HP Pavilion 15-ba003ds Charging Port Replacement: étape 4, image 2 de 3 HP Pavilion 15-ba003ds Charging Port Replacement: étape 4, image 3 de 3
    • Unplug the white connector using your fingers or a spudger.
  5. HP Pavilion 15-ba003ds Charging Port Replacement: étape 5, image 1 de 3 HP Pavilion 15-ba003ds Charging Port Replacement: étape 5, image 2 de 3 HP Pavilion 15-ba003ds Charging Port Replacement: étape 5, image 3 de 3
    • Pull out the fan by hand.
  6. HP Pavilion 15-ba003ds Charging Port Replacement, Charging Port: étape 6, image 1 de 1
    • Use a spudger to disconnect the power cable from the motherboard.
  7. HP Pavilion 15-ba003ds Charging Port Replacement: étape 7, image 1 de 3 HP Pavilion 15-ba003ds Charging Port Replacement: étape 7, image 2 de 3 HP Pavilion 15-ba003ds Charging Port Replacement: étape 7, image 3 de 3
    • Remove two 8mm Phillips #2 screws from the metal plate.
    • Use your hand to flip the metal plate so you can see the charging port fully.
  8. HP Pavilion 15-ba003ds Charging Port Replacement: étape 8, image 1 de 2 HP Pavilion 15-ba003ds Charging Port Replacement: étape 8, image 2 de 2
    • Use a spudger to pry off the charging port.
LI XU
Membre depuis le 01/14/20
334 Réputation
2 tutoriels rédigés
Équipe
York University, Team S1-G9, Woodhouse Winter 2020 Membre de l'équipe York University, Team S1-G9, Woodhouse Winter 2020
YORK-WOODHOUSE-W20S1G9
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 8
30 derniers jours : 39
Total : 2,202
