Aller au contenu principal
HP Pavilion 15-ca2073cl Cooling Fan Replacement
Ce dont vous avez besoin
  1. HP Pavilion 15-ca2073cl Cooling Fan Replacement, Back Cover: étape 1, image 1 de 1
    • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
    • Flip the laptop over.
    • Remove all the 6.5mm screws (black) and the 4.8mm long screws (silver) using the Phillips #00 screwdriver.
  2. HP Pavilion 15-ca2073cl Cooling Fan Replacement: étape 2, image 1 de 2 HP Pavilion 15-ca2073cl Cooling Fan Replacement: étape 2, image 2 de 2
    • Use an iFixit opening tool to wedge in between the case and the body of the laptop.
    • Start from the front and work down both sides, disconnecting clips.
    • Remove the bottom case from the body.
  3. HP Pavilion 15-ca2073cl Cooling Fan Replacement, Battery: étape 3, image 1 de 2 HP Pavilion 15-ca2073cl Cooling Fan Replacement, Battery: étape 3, image 2 de 2
    • Remove six 4.8mm screws (silver) using the Phillips #00 screwdriver.
  4. HP Pavilion 15-ca2073cl Cooling Fan Replacement, Cooling Fan: étape 4, image 1 de 2 HP Pavilion 15-ca2073cl Cooling Fan Replacement, Cooling Fan: étape 4, image 2 de 2
    • Remove the five silver 4.3 mm screws securing the fans using a Phillips #0 screwdriver.
  5. HP Pavilion 15-ca2073cl Cooling Fan Replacement: étape 5, image 1 de 2 HP Pavilion 15-ca2073cl Cooling Fan Replacement: étape 5, image 2 de 2
    • Remove the two cables from their connectors on the motherboard.
  6. HP Pavilion 15-ca2073cl Cooling Fan Replacement: étape 6, image 1 de 3 HP Pavilion 15-ca2073cl Cooling Fan Replacement: étape 6, image 2 de 3 HP Pavilion 15-ca2073cl Cooling Fan Replacement: étape 6, image 3 de 3
    • Lift and remove one cooling fan at a time from the laptop.
Un commentaire
Thank you for making this post.
Adam Mallicoat - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 490
