Introduction
For this guide, you will be instructed on how to replace the display-pad on the HP Pavilion 15-ca2073cl. Before progression, be sure that the battery is off and the back cover is off as well.
Ce dont vous avez besoin
Flip the laptop over.
Remove all the 6.5mm screws (black) and the 4.8mm long screws (silver) using the Phillips #00 screwdriver.
Open the laptop like you normally would if you were about to use it and use a plastic spudger to separate the top cover from the bottom.
While lifting the top cover, undo the clip holding the keyboard cable in place and pull the cable out.
