Aller au contenu principal
HP Pavilion 15-ca2073cl SD Card Reader Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. HP Pavilion 15-ca2073cl SD Card Reader Replacement, Back Cover: étape 1, image 1 de 1
    • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
    • Flip the laptop over.
    • Remove all the 6.5mm screws (black) and the 4.8mm long screws (silver) using the Phillips #00 screwdriver.
  2. HP Pavilion 15-ca2073cl SD Card Reader Replacement: étape 2, image 1 de 2 HP Pavilion 15-ca2073cl SD Card Reader Replacement: étape 2, image 2 de 2
    • Use an iFixit opening tool to wedge in between the case and the body of the laptop.
    • Start from the front and work down both sides, disconnecting clips.
    • Remove the bottom case from the body.
  3. HP Pavilion 15-ca2073cl SD Card Reader Replacement, Battery: étape 3, image 1 de 2 HP Pavilion 15-ca2073cl SD Card Reader Replacement, Battery: étape 3, image 2 de 2
    • Remove six 4.8mm screws (silver) using the Phillips #00 screwdriver.
  4. HP Pavilion 15-ca2073cl SD Card Reader Replacement, SD Card Reader: étape 4, image 1 de 3 HP Pavilion 15-ca2073cl SD Card Reader Replacement, SD Card Reader: étape 4, image 2 de 3 HP Pavilion 15-ca2073cl SD Card Reader Replacement, SD Card Reader: étape 4, image 3 de 3
    • Use a spudger to flip up the retaining flap securing the ribbon cable
    • Remove the white ribbon cable from its connector.
  5. HP Pavilion 15-ca2073cl SD Card Reader Replacement: étape 5, image 1 de 1
    • Remove the single silver 4.3 mm screw with a Phillips #0 screwdriver.
  6. HP Pavilion 15-ca2073cl SD Card Reader Replacement: étape 6, image 1 de 1
    • Remove the SD card reader from the laptop.
Hunter Hamilton
Membre depuis le 09/20/21
125 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 6
Total : 271
