Aller au contenu principal
HP Pavilion 15-ca2073cl Touchpad Replacement
Ce dont vous avez besoin
  1. HP Pavilion 15-ca2073cl Touchpad Replacement, Back Cover: étape 1, image 1 de 1
    • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
    • Flip the laptop over.
    • Remove all the 6.5mm screws (black) and the 4.8mm long screws (silver) using the Phillips #00 screwdriver.
  2. HP Pavilion 15-ca2073cl Touchpad Replacement: étape 2, image 1 de 2 HP Pavilion 15-ca2073cl Touchpad Replacement: étape 2, image 2 de 2
    • Use an iFixit opening tool to wedge in between the case and the body of the laptop.
    • Start from the front and work down both sides, disconnecting clips.
    • Remove the bottom case from the body.
  3. HP Pavilion 15-ca2073cl Touchpad Replacement, Battery: étape 3, image 1 de 2 HP Pavilion 15-ca2073cl Touchpad Replacement, Battery: étape 3, image 2 de 2
    • Remove six 4.8mm screws (silver) using the Phillips #00 screwdriver.
  4. HP Pavilion 15-ca2073cl Touchpad Replacement, Touchpad: étape 4, image 1 de 2 HP Pavilion 15-ca2073cl Touchpad Replacement, Touchpad: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Once the battery is removed, use the tweezers to disconnect the smaller ribbon cable that is attached to the touchpad and motherboard.
    • Proceed to disconnect the larger ribbon cable that is attached to the touchpad and motherboard.
  5. HP Pavilion 15-ca2073cl Touchpad Replacement: étape 5, image 1 de 2 HP Pavilion 15-ca2073cl Touchpad Replacement: étape 5, image 2 de 2
    • Using a screwdriver with a Phillips #00 screwdriver, remove the three screws on the metal touchpad bracket. Remove the bracket.
  6. HP Pavilion 15-ca2073cl Touchpad Replacement: étape 6, image 1 de 1
    • Using the tweezers, pull back the adhesive tape at the top of the touchpad.
    • Using the screwdriver with a Phillips #00 screwdriver, remove the two screws at the top of the touchpad.
  7. HP Pavilion 15-ca2073cl Touchpad Replacement: étape 7, image 1 de 1
    • Gently remove the touchpad from the laptop.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 30
Total : 710
