Aller au contenu principal
HP Pavilion 15-cc023cl Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion 15-cc023cl Hard Drive Replacement, Battery: étape 1, image 1 de 2 HP Pavilion 15-cc023cl Hard Drive Replacement, Battery: étape 1, image 2 de 2
    • Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
  2. HP Pavilion 15-cc023cl Hard Drive Replacement: étape 2, image 1 de 1
    • Using the iFixit opening tool, pry open and remove the back cover of the laptop.
    • Be gentle when applying force to the cover.
  3. HP Pavilion 15-cc023cl Hard Drive Replacement: étape 3, image 1 de 2 HP Pavilion 15-cc023cl Hard Drive Replacement: étape 3, image 2 de 2
    • Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery.
  4. HP Pavilion 15-cc023cl Hard Drive Replacement: étape 4, image 1 de 2 HP Pavilion 15-cc023cl Hard Drive Replacement: étape 4, image 2 de 2
    • Disconnect the port connecting the battery and the motherboard and then remove.
  5. HP Pavilion 15-cc023cl Hard Drive Replacement, Hard Drive: étape 5, image 1 de 1
    • Use a spudger to lift the latch that holds the hard drive cable in place.
  6. HP Pavilion 15-cc023cl Hard Drive Replacement: étape 6, image 1 de 1
    • Use a plastic opening tool to pry the hard drive out.
  7. HP Pavilion 15-cc023cl Hard Drive Replacement: étape 7, image 1 de 1
    • Disconnect the hard drive cable.
  8. HP Pavilion 15-cc023cl Hard Drive Replacement: étape 8, image 1 de 1
    • Lift the plastic wedges up on both sides of the hard drive.
4 autres ont terminé cette réparation.
Stephanie Henry
Membre depuis le 10/02/18
1 077 Réputation
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 25
Total : 4,239
