Aller au contenu principal
HP Pavilion 15-d017cl RAM Replacement
Ce dont vous avez besoin
  1. HP Pavilion 15-d017cl RAM Replacement, Battery: étape 1, image 1 de 3 HP Pavilion 15-d017cl RAM Replacement, Battery: étape 1, image 2 de 3 HP Pavilion 15-d017cl RAM Replacement, Battery: étape 1, image 3 de 3
    • To unlock the top left latch, place your finger on the black latch and slide toward the center of the computer.
    • You do not need to hold this latch when removing the battery.
  2. HP Pavilion 15-d017cl RAM Replacement: étape 2, image 1 de 1
    • To unlock the top right latch, slide the black latch towards the center of the computer.
  3. HP Pavilion 15-d017cl RAM Replacement: étape 3, image 1 de 1
    • The right latch is spring loaded, hold the latch towards the center of the computer.
    • To remove the battery, pull the battery bar away from the computer.
  4. HP Pavilion 15-d017cl RAM Replacement, RAM: étape 4, image 1 de 2 HP Pavilion 15-d017cl RAM Replacement, RAM: étape 4, image 2 de 2
    • Flip the laptop onto its back in order to have access to the back panel.
    • Using a Phillips #1 Screwdriver, unscrew the 5mm screw until the L-shaped panel feels like it can be removed.
  5. HP Pavilion 15-d017cl RAM Replacement: étape 5, image 1 de 2 HP Pavilion 15-d017cl RAM Replacement: étape 5, image 2 de 2
    • To remove the L-shaped panel, use the plastic opening tool to pry the panel from the back of the laptop. Make sure to move the tool the entire way around the panel.
    • This may require a good amount of strength to loosen the panel. As the opening tool is moving around the panel, clicking noises will be heard.
  6. HP Pavilion 15-d017cl RAM Replacement: étape 6, image 1 de 3 HP Pavilion 15-d017cl RAM Replacement: étape 6, image 2 de 3 HP Pavilion 15-d017cl RAM Replacement: étape 6, image 3 de 3
    • Using a spudger, press down on the silver latches that are holding the RAM in place. The RAM looks like a blue rectangle and has a size of about 1 x 2 inches. A slight click will be heard, and the RAM should pop out. You can then pull it away from the laptop.
    • Now that the old RAM has been removed, the new RAM can be inserted back into the laptop by pressing it gently into the place where the old RAM was.
4 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 347
