Aller au contenu principal
HP Pavilion 15-d035dx Front Panel Replacement
Ce dont vous avez besoin
  1. HP Pavilion 15-d035dx Front Panel Replacement, Battery: étape 1, image 1 de 3 HP Pavilion 15-d035dx Front Panel Replacement, Battery: étape 1, image 2 de 3 HP Pavilion 15-d035dx Front Panel Replacement, Battery: étape 1, image 3 de 3
    • Switch the first lock, with the padlock icon, to the open position.
    • Then hold the second lock with the battery icon to the open position, while sliding out the battery pack.
  2. HP Pavilion 15-d035dx Front Panel Replacement, Front Panel: étape 2, image 1 de 1
    • Begin by laying the laptop on its backside with the bottom of the laptop facing you.
  3. HP Pavilion 15-d035dx Front Panel Replacement: étape 3, image 1 de 2 HP Pavilion 15-d035dx Front Panel Replacement: étape 3, image 2 de 2
    • There will be 11, 2.5x3.0mm Philips head screws that you will need to locate.
    • Continue by unscrewing all of them using a 0 Phillips screwdriver.
  4. HP Pavilion 15-d035dx Front Panel Replacement: étape 4, image 1 de 3 HP Pavilion 15-d035dx Front Panel Replacement: étape 4, image 2 de 3 HP Pavilion 15-d035dx Front Panel Replacement: étape 4, image 3 de 3
    • Take off the back panel by removing the 4.0x4.7mm Philips head screw.
    • Then using the opening tool, work around the edges to pull off the back panel.
    • It will take some force to get the back panel off.
  5. HP Pavilion 15-d035dx Front Panel Replacement: étape 5, image 1 de 1
    • Now flip the computer right side up and open up the laptop.
    • You should be facing the screen and keyboard.
  6. HP Pavilion 15-d035dx Front Panel Replacement: étape 6, image 1 de 1
    • Now using the opening tool remove the front panel from the back panel.
    • It should start to pop off, you will have to do this step around the entire computer.
    • It will give some resistance so take your time to ensure that nothing breaks.
  7. HP Pavilion 15-d035dx Front Panel Replacement: étape 7, image 1 de 1
    • Once you have popped off the panel it should simply be able to lift off of the laptop.
    • Keep in mind that the keyboard is still connected to the motherboard. Simply lay the keyboard on top of the screen while you are completing future guides.
    • You can replace the front panel now.
John Atkins
Membre depuis le 09/25/17
273 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 4
30 derniers jours : 9
Total : 1,036
