Aller au contenu principal
HP Pavilion 15-d035dx RAM Replacement
Ce dont vous avez besoin
  1. HP Pavilion 15-d035dx RAM Replacement, Battery: étape 1, image 1 de 3 HP Pavilion 15-d035dx RAM Replacement, Battery: étape 1, image 2 de 3 HP Pavilion 15-d035dx RAM Replacement, Battery: étape 1, image 3 de 3
    • Switch the first lock, with the padlock icon, to the open position.
    • Then hold the second lock with the battery icon to the open position, while sliding out the battery pack.
  2. HP Pavilion 15-d035dx RAM Replacement, Back Panel: étape 2, image 1 de 1
    • Flip the laptop so that the back is facing upwards.
    • Locate the small screw on the back that holds the "L" shaped panel.
    • Using a 0 Phillip Screwdriver (4.0x4.7mm sized screw), unscrew the screw. It will not become detached from the panel but it will allow you to remove the back panel.
  3. HP Pavilion 15-d035dx RAM Replacement: étape 3, image 1 de 3 HP Pavilion 15-d035dx RAM Replacement: étape 3, image 2 de 3 HP Pavilion 15-d035dx RAM Replacement: étape 3, image 3 de 3
    • Using a plastic opening tool, pry the back panel from the computer, going all the way around it.
    • This will take a good amount of force and you will hear clicking noises as you snap each of the connections out of place.
  4. HP Pavilion 15-d035dx RAM Replacement: étape 4, image 1 de 1
    • Once the back panel is completely removed you will have access to the RAM and many other connections in the computer.
  5. HP Pavilion 15-d035dx RAM Replacement, RAM: étape 5, image 1 de 1
    • Locate the RAM, it is about a 2 inch by 1 inch rectangle that is blue in color.
  6. HP Pavilion 15-d035dx RAM Replacement: étape 6, image 1 de 1
    • Press down on the small silver latches on either side of the RAM, the RAM should pop up. While doing this you will hear a faint click.
  7. HP Pavilion 15-d035dx RAM Replacement: étape 7, image 1 de 1
    • Finally remove the RAM by pulling it away from the black connection panel.
    • Once the RAM is removed you can put in the replacement RAM.
Meredith Shaffer
Membre depuis le 09/25/17
222 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 8
Total : 417
