Introduction
In this guide you will learn how to safely remove and replace the RAM in this laptop.
Ce dont vous avez besoin
Switch the first lock, with the padlock icon, to the open position.
Then hold the second lock with the battery icon to the open position, while sliding out the battery pack.
Flip the laptop so that the back is facing upwards.
Locate the small screw on the back that holds the "L" shaped panel.
Using a 0 Phillip Screwdriver (4.0x4.7mm sized screw), unscrew the screw. It will not become detached from the panel but it will allow you to remove the back panel.
Locate the RAM, it is about a 2 inch by 1 inch rectangle that is blue in color.
