Aller au contenu principal
HP Pavilion 15-n210dx Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion 15-n210dx Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Turn the laptop over.
  2. HP Pavilion 15-n210dx Hard Drive Replacement: étape 2, image 1 de 3 HP Pavilion 15-n210dx Hard Drive Replacement: étape 2, image 2 de 3 HP Pavilion 15-n210dx Hard Drive Replacement: étape 2, image 3 de 3
    • Push the pins towards each other using your thumbs. The battery will pop out a little bit. Remove it using your hand.
  3. HP Pavilion 15-n210dx Hard Drive Replacement, Keyboard: étape 3, image 1 de 1
    • Turn over the laptop and remove the single screw using a Tri-point Y0 screwdriver.
  4. HP Pavilion 15-n210dx Hard Drive Replacement: étape 4, image 1 de 1
    • Open the laptop and use a spudger gently to get under the keyboard. Loosen the keyboard on all sides and then lift it up.
  5. HP Pavilion 15-n210dx Hard Drive Replacement: étape 5, image 1 de 2 HP Pavilion 15-n210dx Hard Drive Replacement: étape 5, image 2 de 2
    • Use the spudger to unhinge the fastener and remove the connector.
    • The keyboard should be completely detached from the computer now.
  6. HP Pavilion 15-n210dx Hard Drive Replacement, Hard Drive: étape 6, image 1 de 1
    • Use the Tri-point Y0 screwdriver to remove all screws on the metal sheet, then remove the metal sheet.
  7. HP Pavilion 15-n210dx Hard Drive Replacement: étape 7, image 1 de 2 HP Pavilion 15-n210dx Hard Drive Replacement: étape 7, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Remove the two blue wire connectors using the reverse tweezers and lift up on the two wires to disconnect them.
  8. HP Pavilion 15-n210dx Hard Drive Replacement: étape 8, image 1 de 1
    • Using the Phillips #0 screwdriver, remove the twelve (12) screws from the back panel.
  9. HP Pavilion 15-n210dx Hard Drive Replacement: étape 9, image 1 de 2 HP Pavilion 15-n210dx Hard Drive Replacement: étape 9, image 2 de 2
    • Remove the optic drive by pushing the edge with your thumbs to open it. Once open use two hands to remove it entirely.
  10. HP Pavilion 15-n210dx Hard Drive Replacement: étape 10, image 1 de 1
    • Remove the screws that become exposed after removing the optic drive using a Phillips #0 screwdriver.
  11. HP Pavilion 15-n210dx Hard Drive Replacement: étape 11, image 1 de 2 HP Pavilion 15-n210dx Hard Drive Replacement: étape 11, image 2 de 2
    • Wedge the metal spudger between the black and silver plastic.
    • Slide the spudger along the edge of the laptop to help in ease of separation. Next use your hands to separate the black plastic from the silver plastic.
    • Avoid using the metal spudger unless it's for serious prying power. If used incorrectly, the metal spudger can damage the internal components of the device.
  12. HP Pavilion 15-n210dx Hard Drive Replacement: étape 12, image 1 de 3 HP Pavilion 15-n210dx Hard Drive Replacement: étape 12, image 2 de 3 HP Pavilion 15-n210dx Hard Drive Replacement: étape 12, image 3 de 3
    • Remove the two connectors that are attached to the hard drive by lifting up and away from the connected port.
  13. HP Pavilion 15-n210dx Hard Drive Replacement: étape 13, image 1 de 1
    • Remove the hard drive by lifting up on the back side of it.
Seth Shea
Membre depuis le 10/25/21
222 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 3-8, Sinclaire Fall 2021 Membre de l'équipe UMass Dartmouth, Team 3-8, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G8
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 28
Total : 1,169
