Aller au contenu principal
HP Pavilion 15-n232nr Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion 15-n232nr Hard Drive Replacement, Battery: étape 1, image 1 de 2 HP Pavilion 15-n232nr Hard Drive Replacement, Battery: étape 1, image 2 de 2
    • Flip the laptop over.
  2. HP Pavilion 15-n232nr Hard Drive Replacement: étape 2, image 1 de 3 HP Pavilion 15-n232nr Hard Drive Replacement: étape 2, image 2 de 3 HP Pavilion 15-n232nr Hard Drive Replacement: étape 2, image 3 de 3
    • Slide the battery locks towards the center of the laptop. The battery will detach automatically.
    • Remove the battery by sliding it away from the laptop housing.
  3. HP Pavilion 15-n232nr Hard Drive Replacement, Keyboard: étape 3, image 1 de 2 HP Pavilion 15-n232nr Hard Drive Replacement, Keyboard: étape 3, image 2 de 2
    • Unscrew the 6 mm Phillips #1 screw securing the keyboard.
  4. HP Pavilion 15-n232nr Hard Drive Replacement: étape 4, image 1 de 2 HP Pavilion 15-n232nr Hard Drive Replacement: étape 4, image 2 de 2
    • Flip the laptop to the front side and open it up.
  5. HP Pavilion 15-n232nr Hard Drive Replacement: étape 5, image 1 de 2 HP Pavilion 15-n232nr Hard Drive Replacement: étape 5, image 2 de 2
    • Use the metal spudger to release the keyboard from the front panel.
  6. HP Pavilion 15-n232nr Hard Drive Replacement: étape 6, image 1 de 3 HP Pavilion 15-n232nr Hard Drive Replacement: étape 6, image 2 de 3 HP Pavilion 15-n232nr Hard Drive Replacement: étape 6, image 3 de 3
    • Flip the keyboard out and locate the connector.
    • Use the spudger to unhinge the the fastener and remove the connector.
    • Keyboard should be completely detached after this step.
  7. HP Pavilion 15-n232nr Hard Drive Replacement, Optical Drive: étape 7, image 1 de 2 HP Pavilion 15-n232nr Hard Drive Replacement, Optical Drive: étape 7, image 2 de 2
    • Remove the 6 mm Phillips #1 screw securing the optical drive.
  8. HP Pavilion 15-n232nr Hard Drive Replacement: étape 8, image 1 de 2 HP Pavilion 15-n232nr Hard Drive Replacement: étape 8, image 2 de 2
    • Use the iFixit opening tool to slide the optical drive away from the laptop housing.
  9. HP Pavilion 15-n232nr Hard Drive Replacement, Hard Drive: étape 9, image 1 de 2 HP Pavilion 15-n232nr Hard Drive Replacement, Hard Drive: étape 9, image 2 de 2
    • The battery and optical drive should be removed at this point in the process.
    • Remove the ten 6 mm Phillips #1 screws.
    • Remove the three 1 mm Phillips #000 screws.
  10. HP Pavilion 15-n232nr Hard Drive Replacement: étape 10, image 1 de 2 HP Pavilion 15-n232nr Hard Drive Replacement: étape 10, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Remove the five 2.5mm Phillips #1 screws.
    • Use the spudger to unhinge the cable connectors. Use tweezers to complete removal.
  11. HP Pavilion 15-n232nr Hard Drive Replacement: étape 11, image 1 de 3 HP Pavilion 15-n232nr Hard Drive Replacement: étape 11, image 2 de 3 HP Pavilion 15-n232nr Hard Drive Replacement: étape 11, image 3 de 3
    • Carefully use the iFixit opening tool to release the front panel.
  12. HP Pavilion 15-n232nr Hard Drive Replacement: étape 12, image 1 de 3 HP Pavilion 15-n232nr Hard Drive Replacement: étape 12, image 2 de 3 HP Pavilion 15-n232nr Hard Drive Replacement: étape 12, image 3 de 3
    • Use the spudger to unhinge the daughterboard connector.
    • Remove daughterboard connector.
  13. HP Pavilion 15-n232nr Hard Drive Replacement: étape 13, image 1 de 1
    • Remove the 2.5 mm Phillips #1 screw and remove the daughterboard
  14. HP Pavilion 15-n232nr Hard Drive Replacement: étape 14, image 1 de 3 HP Pavilion 15-n232nr Hard Drive Replacement: étape 14, image 2 de 3 HP Pavilion 15-n232nr Hard Drive Replacement: étape 14, image 3 de 3
    • Use the iFixit opening tool to remove the hard drive connector.
    • Remove the hard drive by lifting the right side and pulling it out.
6 autres ont terminé cette réparation.
Trey Stutts
Membre depuis le 03/18/19
247 Réputation
1 tutoriel rédigé
Équipe
2 commentaires
How to test it's processor
Kashmir Singh - Réponse
Great guide, thank you!!
alt255d - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 9
Total : 1,378
