Aller au contenu principal
HP Pavilion 15-p043cl Repair Optical Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion 15-p043cl Repair Optical Drive Replacement, Optical Drive: étape 1, image 1 de 2 HP Pavilion 15-p043cl Repair Optical Drive Replacement, Optical Drive: étape 1, image 2 de 2
    • Flip over the laptop so that the screws on the bottom are exposed.
  2. HP Pavilion 15-p043cl Repair Optical Drive Replacement: étape 2, image 1 de 2 HP Pavilion 15-p043cl Repair Optical Drive Replacement: étape 2, image 2 de 2
    • Use a #1 Phillips screwdriver to remove the single 8 mm screw that secures the optical drive.
    • There is a CD/DVD symbol on the case that helps identify the correct screw.
  3. HP Pavilion 15-p043cl Repair Optical Drive Replacement: étape 3, image 1 de 3 HP Pavilion 15-p043cl Repair Optical Drive Replacement: étape 3, image 2 de 3 HP Pavilion 15-p043cl Repair Optical Drive Replacement: étape 3, image 3 de 3
    • Use your fingers or a wedge to pull out the Optical Drive from it's slot.
    • If the faceplate of the drive is pulled off it can be reattached.
Teague Mendez
Membre depuis le 10/01/23
692 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 3
Total : 58
