Aller au contenu principal
HP Pavilion 15-p043cl Repair RAM Replacement
Ce dont vous avez besoin
  1. HP Pavilion 15-p043cl Repair RAM Replacement, Optical Drive: étape 1, image 1 de 2 HP Pavilion 15-p043cl Repair RAM Replacement, Optical Drive: étape 1, image 2 de 2
    • Flip over the laptop so that the screws on the bottom are exposed.
  2. HP Pavilion 15-p043cl Repair RAM Replacement: étape 2, image 1 de 2 HP Pavilion 15-p043cl Repair RAM Replacement: étape 2, image 2 de 2
    • Use a #1 Phillips screwdriver to remove the single 8 mm screw that secures the optical drive.
    • There is a CD/DVD symbol on the case that helps identify the correct screw.
  3. HP Pavilion 15-p043cl Repair RAM Replacement: étape 3, image 1 de 3 HP Pavilion 15-p043cl Repair RAM Replacement: étape 3, image 2 de 3 HP Pavilion 15-p043cl Repair RAM Replacement: étape 3, image 3 de 3
    • Use your fingers or a wedge to pull out the Optical Drive from it's slot.
    • If the faceplate of the drive is pulled off it can be reattached.
  4. HP Pavilion 15-p043cl Repair RAM Replacement, RAM: étape 4, image 1 de 3 HP Pavilion 15-p043cl Repair RAM Replacement, RAM: étape 4, image 2 de 3 HP Pavilion 15-p043cl Repair RAM Replacement, RAM: étape 4, image 3 de 3
    • Use a #1 Phillips-head screwdriver to remove the ten additional 8 mm bottom case screws.
  5. HP Pavilion 15-p043cl Repair RAM Replacement: étape 5, image 1 de 2 HP Pavilion 15-p043cl Repair RAM Replacement: étape 5, image 2 de 2
    • Pull out the battery by positioning the switch with the lock symbol on unlock and pushing the switch with the battery towards the center of the laptop
  6. HP Pavilion 15-p043cl Repair RAM Replacement: étape 6, image 1 de 3 HP Pavilion 15-p043cl Repair RAM Replacement: étape 6, image 2 de 3 HP Pavilion 15-p043cl Repair RAM Replacement: étape 6, image 3 de 3
    • Flip over the laptop so the HP symbol is facing up.
    • Open the lid of the laptop.
    • Using the spudger, pry between the case and keyboard/mousepad area. Work all the way around the case.
  7. HP Pavilion 15-p043cl Repair RAM Replacement: étape 7, image 1 de 3 HP Pavilion 15-p043cl Repair RAM Replacement: étape 7, image 2 de 3 HP Pavilion 15-p043cl Repair RAM Replacement: étape 7, image 3 de 3
    • Carefully remove the keyboard area.
    • Make sure to unplug the 3 ribbon cables connecting the keyboard. mousepad, and power button to the motherboard.
  8. HP Pavilion 15-p043cl Repair RAM Replacement: étape 8, image 1 de 2 HP Pavilion 15-p043cl Repair RAM Replacement: étape 8, image 2 de 2
    • Remove the remaining ribbon cables.
    • Remove the connection to the HDMI port.
  9. HP Pavilion 15-p043cl Repair RAM Replacement: étape 9, image 1 de 3 HP Pavilion 15-p043cl Repair RAM Replacement: étape 9, image 2 de 3 HP Pavilion 15-p043cl Repair RAM Replacement: étape 9, image 3 de 3
    • Remove the remaining motherboard screws.
    • Gently lift the motherboard up, towards the screen of the laptop. Remove the remaining display connector.
  10. HP Pavilion 15-p043cl Repair RAM Replacement: étape 10, image 1 de 2 HP Pavilion 15-p043cl Repair RAM Replacement: étape 10, image 2 de 2
    • Locate the RAM.
    • Pull the metal tabs to the side while pulling the RAM module out and slightly up.
Teague Mendez
Membre depuis le 10/01/23
692 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 6
Total : 80
