Aller au contenu principal
HP Pavilion 15-p214dx Disk Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion 15-p214dx Disk Drive Replacement, Disk Drive: étape 1, image 1 de 3 HP Pavilion 15-p214dx Disk Drive Replacement, Disk Drive: étape 1, image 2 de 3 HP Pavilion 15-p214dx Disk Drive Replacement, Disk Drive: étape 1, image 3 de 3
    • Place your laptop on a flat surface with the bottom facing upwards. The HP logo should be facing downwards.
    • Locate the disk drive screw. It is a 7mm screw that can be found to the upper left on label on the bottom of the computer and is marked with a disk drive symbol.
    • Remove this screw using a Philips #0 screwdriver.
  2. HP Pavilion 15-p214dx Disk Drive Replacement: étape 2, image 1 de 2 HP Pavilion 15-p214dx Disk Drive Replacement: étape 2, image 2 de 2
    • Place your thumbnail between the disk drive exterior and your laptop's bottom cover.
    • If your nail is not long enough to do this, you can use a prying tool instead.
    • Pull outwards to slide the disk drive out of its slot.
    • Due to how the disk drive's slot is constructed, the drive must be properly aligned to fit back in. It may take a couple attempts to properly align it.
Patrick Seaver
Membre depuis le 03/25/19
1 001 Réputation
8 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G1, Simcock Spring 2019 Membre de l'équipe UMass Dartmouth, Team S2-G1, Simcock Spring 2019
UMASSD-SIMCOCK-S19S2G1
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 244
