Introduction
This guide discusses how to remove the HP Pavilion 15-p214dx’s motherboard. To do this, you will need a Philips #0 screwdriver, a plastic opening tool, and a flathead screwdriver. Since the motherboard is one of the laptop’s most important parts, it should be handled and removed with care.
Ce dont vous avez besoin
Place your laptop on a flat surface with the bottom facing upwards. The HP logo should be facing downwards.
Locate the disk drive screw. It is a 7mm screw that can be found to the upper left on label on the bottom of the computer and is marked with a disk drive symbol.
Remove this screw using a Philips #0 screwdriver.
Using a magnetic screwdriver with a Philips #0 head, remove all of the visible screws on your laptop's bottom face. These screws are all about 7.5mm long.
