Introduction
If you need to open your HP Pavilion 15-p214dx to access any of its internal components, this guide will walk you through how to remove the laptop’s top cover. This guide can also be used when you need to remove your computer’s keyboard since it is completely integrated into the top cover. To do this, you will need a Philips #0 screwdriver, a plastic opening tool, and possibly a flathead screwdriver.
Ce dont vous avez besoin
Place your laptop on a flat surface with the bottom facing upwards. The HP logo should be facing downwards.
Locate the disk drive screw. It is a 7mm screw that can be found to the upper left on label on the bottom of the computer and is marked with a disk drive symbol.
Remove this screw using a Philips #0 screwdriver.
Using a magnetic screwdriver with a Philips #0 head, remove all of the visible screws on your laptop's bottom face. These screws are all about 7.5mm long.
