Aller au contenu principal
HP Pavilion 17-ak008cy Motherboard Replacement
Ce dont vous avez besoin
  1. HP Pavilion 17-ak008cy Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Flip the laptop over so that the underside is facing you.
  2. HP Pavilion 17-ak008cy Motherboard Replacement: étape 2, image 1 de 3 HP Pavilion 17-ak008cy Motherboard Replacement: étape 2, image 2 de 3 HP Pavilion 17-ak008cy Motherboard Replacement: étape 2, image 3 de 3
    • Using your hands, push the two tabs inwards to release the battery.
    • Remove the battery from the device.
  3. HP Pavilion 17-ak008cy Motherboard Replacement, Back Panel: étape 3, image 1 de 2 HP Pavilion 17-ak008cy Motherboard Replacement, Back Panel: étape 3, image 2 de 2
    • Remove eleven screws from the back panel.
    • Remove the back panel from the device.
  4. HP Pavilion 17-ak008cy Motherboard Replacement, Fan: étape 4, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the single screw securing the fan to the motherboard.
  5. HP Pavilion 17-ak008cy Motherboard Replacement: étape 5, image 1 de 2 HP Pavilion 17-ak008cy Motherboard Replacement: étape 5, image 2 de 2
    • Disconnect the fan wire carefully so that the fan is longer connected to the motherboard.
  6. HP Pavilion 17-ak008cy Motherboard Replacement: étape 6, image 1 de 2 HP Pavilion 17-ak008cy Motherboard Replacement: étape 6, image 2 de 2
    • Remove the fan from the device.
  7. HP Pavilion 17-ak008cy Motherboard Replacement, Hard Drive: étape 7, image 1 de 2 HP Pavilion 17-ak008cy Motherboard Replacement, Hard Drive: étape 7, image 2 de 2
    • Carefully detach the connector above the hard drive.
    • Remove the hard drive from the device.
  8. HP Pavilion 17-ak008cy Motherboard Replacement, Motherboard: étape 8, image 1 de 3 HP Pavilion 17-ak008cy Motherboard Replacement, Motherboard: étape 8, image 2 de 3 HP Pavilion 17-ak008cy Motherboard Replacement, Motherboard: étape 8, image 3 de 3
    • Disconnect all of the cables attached to the motherboard.
    • Many of these wires are delicate so be careful when unplugging them.
  9. HP Pavilion 17-ak008cy Motherboard Replacement: étape 9, image 1 de 2 HP Pavilion 17-ak008cy Motherboard Replacement: étape 9, image 2 de 2
    • Using a Phillips #0 screwdriver, remove eight screws from the motherboard.
    • Using the same screwdriver, remove four screws from the motherboard.
  10. HP Pavilion 17-ak008cy Motherboard Replacement: étape 10, image 1 de 2 HP Pavilion 17-ak008cy Motherboard Replacement: étape 10, image 2 de 2
    • Gently lift and remove the motherboard from the device.
Andrew Boardman
Membre depuis le 10/25/21
487 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-2, Sinclaire Fall 2021 Membre de l'équipe UMass Dartmouth, Team 2-2, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G2
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 15
Total : 190
