Aller au contenu principal
HP Pavilion 17-e117dx Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion 17-e117dx Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Turn the laptop upside down, so that the bottom is facing up.
  2. HP Pavilion 17-e117dx Hard Drive Replacement: étape 2, image 1 de 2 HP Pavilion 17-e117dx Hard Drive Replacement: étape 2, image 2 de 2
    • Slide the battery release latch to the left. The battery will pop up slightly.
    • Lift the battery upwards and out of the laptop.
  3. HP Pavilion 17-e117dx Hard Drive Replacement, Service Panel: étape 3, image 1 de 2 HP Pavilion 17-e117dx Hard Drive Replacement, Service Panel: étape 3, image 2 de 2
    • Using a Phillips #00 screwdriver, remove the single Phillips 3.0 x 10.5 mm screw that fastens the service panel to the laptop.
  4. HP Pavilion 17-e117dx Hard Drive Replacement: étape 4, image 1 de 1
    • Slide the service panel towards you to loosen it from the laptop.
  5. HP Pavilion 17-e117dx Hard Drive Replacement: étape 5, image 1 de 1
    • Remove the service panel.
  6. HP Pavilion 17-e117dx Hard Drive Replacement, Hard Drive: étape 6, image 1 de 3 HP Pavilion 17-e117dx Hard Drive Replacement, Hard Drive: étape 6, image 2 de 3 HP Pavilion 17-e117dx Hard Drive Replacement, Hard Drive: étape 6, image 3 de 3
    • Remove the two Phillips 2.5 x 5.75 mm screws that hold the hard drive down to the computer.
    • Use the Phillips #00 screwdriver.
  7. HP Pavilion 17-e117dx Hard Drive Replacement: étape 7, image 1 de 3 HP Pavilion 17-e117dx Hard Drive Replacement: étape 7, image 2 de 3 HP Pavilion 17-e117dx Hard Drive Replacement: étape 7, image 3 de 3
    • Disconnect the hard drive connector cable from the computer's system board.
  8. HP Pavilion 17-e117dx Hard Drive Replacement: étape 8, image 1 de 2 HP Pavilion 17-e117dx Hard Drive Replacement: étape 8, image 2 de 2
    • Lift the hard drive out of the hard drive bay by lifting up from the tab.
    • Remove the hard drive from the computer.
2 autres ont terminé cette réparation.
Marcel Amazan
Membre depuis le 03/24/19
576 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S8-G5, Bailey Spring 2019 Membre de l'équipe UMass Dartmouth, Team S8-G5, Bailey Spring 2019
UMASSD-BAILEY-S19S8G5
2 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 31
Total : 1,657
