Aller au contenu principal
HP Pavilion 17-e117dx Optical Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion 17-e117dx Optical Drive Replacement, Battery: étape 1, image 1 de 1
    • Turn the laptop upside down, so that the bottom is facing up.
  2. HP Pavilion 17-e117dx Optical Drive Replacement: étape 2, image 1 de 2 HP Pavilion 17-e117dx Optical Drive Replacement: étape 2, image 2 de 2
    • Slide the battery release latch to the left. The battery will pop up slightly.
    • Lift the battery upwards and out of the laptop.
  3. HP Pavilion 17-e117dx Optical Drive Replacement, Service Panel: étape 3, image 1 de 2 HP Pavilion 17-e117dx Optical Drive Replacement, Service Panel: étape 3, image 2 de 2
    • Using a Phillips #00 screwdriver, remove the single Phillips 3.0 x 10.5 mm screw that fastens the service panel to the laptop.
  4. HP Pavilion 17-e117dx Optical Drive Replacement: étape 4, image 1 de 1
    • Slide the service panel towards you to loosen it from the laptop.
  5. HP Pavilion 17-e117dx Optical Drive Replacement: étape 5, image 1 de 1
    • Remove the service panel.
  6. HP Pavilion 17-e117dx Optical Drive Replacement, Optical Drive: étape 6, image 1 de 2 HP Pavilion 17-e117dx Optical Drive Replacement, Optical Drive: étape 6, image 2 de 2
    • Remove the single Phillips PM 2.5 x 5.75 screw that secures the optical drive to the computer.
    • Use the Phillips #00 screwdriver.
  7. HP Pavilion 17-e117dx Optical Drive Replacement: étape 7, image 1 de 3 HP Pavilion 17-e117dx Optical Drive Replacement: étape 7, image 2 de 3 HP Pavilion 17-e117dx Optical Drive Replacement: étape 7, image 3 de 3
    • Slide the optical drive out of the computer.
Marcel Amazan
Membre depuis le 03/24/19
576 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S8-G5, Bailey Spring 2019 Membre de l'équipe UMass Dartmouth, Team S8-G5, Bailey Spring 2019
UMASSD-BAILEY-S19S8G5
2 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 6
Total : 356
