Aller au contenu principal
HP Pavilion 17-f004dx Front Panel Replacement
Ce dont vous avez besoin
  1. HP Pavilion 17-f004dx Front Panel Replacement, Battery: étape 1, image 1 de 1
    • Before you remove the battery, make sure the laptop is powered off.
    • Slide the black battery latches inward to remove the battery.
  2. HP Pavilion 17-f004dx Front Panel Replacement: étape 2, image 1 de 1
    • Pull the battery out towards you while your fingers are still holding the latches in place.
  3. HP Pavilion 17-f004dx Front Panel Replacement, CD Drive: étape 3, image 1 de 1
    • Remove one 7 mm screw with a Phillips #1 screwdriver.
  4. HP Pavilion 17-f004dx Front Panel Replacement: étape 4, image 1 de 3 HP Pavilion 17-f004dx Front Panel Replacement: étape 4, image 2 de 3 HP Pavilion 17-f004dx Front Panel Replacement: étape 4, image 3 de 3
    • Use a metal spudger to push the CD drive out of its slot for removal.
  5. HP Pavilion 17-f004dx Front Panel Replacement, Front Panel: étape 5, image 1 de 1
    • Remove fifteen 7 mm screws with a Phillips #1 screwdriver.
  6. HP Pavilion 17-f004dx Front Panel Replacement: étape 6, image 1 de 2 HP Pavilion 17-f004dx Front Panel Replacement: étape 6, image 2 de 2
    • Remove the thin plastic cover using the flat metal spudger to expose another screw.
    • Remove one 7 mm screw with a Phillips #0 screwdriver.
  7. HP Pavilion 17-f004dx Front Panel Replacement: étape 7, image 1 de 2 HP Pavilion 17-f004dx Front Panel Replacement: étape 7, image 2 de 2
    • Use a metal spudger to remove the rubber "feet" to expose two screws.
  8. HP Pavilion 17-f004dx Front Panel Replacement: étape 8, image 1 de 1
    • Underneath each rubber foot, there is a screw.
    • Use the Phillips #1 screwdriver to remove a 4.8 mm screw on each side.
  9. HP Pavilion 17-f004dx Front Panel Replacement: étape 9, image 1 de 1
    • Remove the two black end caps to expose more screws.
    • The end caps will require some force to remove.
  10. HP Pavilion 17-f004dx Front Panel Replacement: étape 10, image 1 de 1
    • Remove the following six screws with a Phillips #1 screwdriver:
    • Two 7 mm screws.
    • Two 7 mm screws.
    • Two 4.8 mm screws.
  11. HP Pavilion 17-f004dx Front Panel Replacement: étape 11, image 1 de 1
    • Remove two 2.4 mm broadhead screws from the CD Drive bay with a Phillips #0 screwdriver.
  12. HP Pavilion 17-f004dx Front Panel Replacement: étape 12, image 1 de 2 HP Pavilion 17-f004dx Front Panel Replacement: étape 12, image 2 de 2
    • Flip the laptop back over. Then, with the laptop open, move the plastic prying tool around the top cover to pry it from the enclosure.
  13. HP Pavilion 17-f004dx Front Panel Replacement: étape 13, image 1 de 1
    • Partially lift the top cover from the enclosure.
  14. HP Pavilion 17-f004dx Front Panel Replacement: étape 14, image 1 de 2 HP Pavilion 17-f004dx Front Panel Replacement: étape 14, image 2 de 2
    • Remove the ribbon connecting the power button to the motherboard.
  15. HP Pavilion 17-f004dx Front Panel Replacement: étape 15, image 1 de 2 HP Pavilion 17-f004dx Front Panel Replacement: étape 15, image 2 de 2
    • Remove the ribbon connecting the mousepad to the motherboard.
  16. HP Pavilion 17-f004dx Front Panel Replacement: étape 16, image 1 de 2 HP Pavilion 17-f004dx Front Panel Replacement: étape 16, image 2 de 2
    • Remove the ribbon connecting the keyboard to the motherboard.
    • You may now fully lift the front panel from the rest of the laptop.
Allan Soria
Membre depuis le 09/21/16
623 Réputation
4 tutoriels rédigés
Équipe
UC Davis, Team 1-4, Oliver Fall 2016 Membre de l'équipe UC Davis, Team 1-4, Oliver Fall 2016
UCD-OLIVER-F16S1G4
4 membres
8 tutoriels rédigés
Un commentaire
I need the fan , how much?
محمد السيد - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 4
Total : 1,237
