Aller au contenu principal
HP Pavilion 17-f004dx Keyboard Replacement
Ce dont vous avez besoin
  1. HP Pavilion 17-f004dx Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Before you remove the battery, make sure the laptop is powered off.
    • Slide the black battery latches inward to remove the battery.
  2. HP Pavilion 17-f004dx Keyboard Replacement: étape 2, image 1 de 1
    • Pull the battery out towards you while your fingers are still holding the latches in place.
  3. HP Pavilion 17-f004dx Keyboard Replacement, CD Drive: étape 3, image 1 de 1
    • Remove one 7 mm screw with a Phillips #1 screwdriver.
  4. HP Pavilion 17-f004dx Keyboard Replacement: étape 4, image 1 de 3 HP Pavilion 17-f004dx Keyboard Replacement: étape 4, image 2 de 3 HP Pavilion 17-f004dx Keyboard Replacement: étape 4, image 3 de 3
    • Use a metal spudger to push the CD drive out of its slot for removal.
  5. HP Pavilion 17-f004dx Keyboard Replacement, Front Panel: étape 5, image 1 de 1
    • Remove fifteen 7 mm screws with a Phillips #1 screwdriver.
  6. HP Pavilion 17-f004dx Keyboard Replacement: étape 6, image 1 de 2 HP Pavilion 17-f004dx Keyboard Replacement: étape 6, image 2 de 2
    • Remove the thin plastic cover using the flat metal spudger to expose another screw.
    • Remove one 7 mm screw with a Phillips #0 screwdriver.
  7. HP Pavilion 17-f004dx Keyboard Replacement: étape 7, image 1 de 2 HP Pavilion 17-f004dx Keyboard Replacement: étape 7, image 2 de 2
    • Use a metal spudger to remove the rubber "feet" to expose two screws.
  8. HP Pavilion 17-f004dx Keyboard Replacement: étape 8, image 1 de 1
    • Underneath each rubber foot, there is a screw.
    • Use the Phillips #1 screwdriver to remove a 4.8 mm screw on each side.
  9. HP Pavilion 17-f004dx Keyboard Replacement: étape 9, image 1 de 1
    • Remove the two black end caps to expose more screws.
    • The end caps will require some force to remove.
  10. HP Pavilion 17-f004dx Keyboard Replacement: étape 10, image 1 de 1
    • Remove the following six screws with a Phillips #1 screwdriver:
    • Two 7 mm screws.
    • Two 7 mm screws.
    • Two 4.8 mm screws.
  11. HP Pavilion 17-f004dx Keyboard Replacement: étape 11, image 1 de 1
    • Remove two 2.4 mm broadhead screws from the CD Drive bay with a Phillips #0 screwdriver.
  12. HP Pavilion 17-f004dx Keyboard Replacement: étape 12, image 1 de 2 HP Pavilion 17-f004dx Keyboard Replacement: étape 12, image 2 de 2
    • Flip the laptop back over. Then, with the laptop open, move the plastic prying tool around the top cover to pry it from the enclosure.
  13. HP Pavilion 17-f004dx Keyboard Replacement: étape 13, image 1 de 1
    • Partially lift the top cover from the enclosure.
  14. HP Pavilion 17-f004dx Keyboard Replacement: étape 14, image 1 de 2 HP Pavilion 17-f004dx Keyboard Replacement: étape 14, image 2 de 2
    • Remove the ribbon connecting the power button to the motherboard.
  15. HP Pavilion 17-f004dx Keyboard Replacement: étape 15, image 1 de 2 HP Pavilion 17-f004dx Keyboard Replacement: étape 15, image 2 de 2
    • Remove the ribbon connecting the mousepad to the motherboard.
  16. HP Pavilion 17-f004dx Keyboard Replacement: étape 16, image 1 de 2 HP Pavilion 17-f004dx Keyboard Replacement: étape 16, image 2 de 2
    • Remove the ribbon connecting the keyboard to the motherboard.
    • You may now fully lift the front panel from the rest of the laptop.
  17. HP Pavilion 17-f004dx Keyboard Replacement, Keyboard: étape 17, image 1 de 1
    • Turn the front panel over and partially remove the clear plastic covering the keyboard casing.
  18. HP Pavilion 17-f004dx Keyboard Replacement: étape 18, image 1 de 2 HP Pavilion 17-f004dx Keyboard Replacement: étape 18, image 2 de 2
    • Plastic debris may scatter while lifting the metal housing. These pieces are indicated in red.
    • Use a metal spudger to remove the metal housing from the front panel.
  19. HP Pavilion 17-f004dx Keyboard Replacement: étape 19, image 1 de 2 HP Pavilion 17-f004dx Keyboard Replacement: étape 19, image 2 de 2
    • Lift the metal housing from the front panel to separate the keyboard from the top panel.
6 autres ont terminé cette réparation.
Chi Huynh
Membre depuis le 09/21/16
675 Réputation
2 tutoriels rédigés
Équipe
UC Davis, Team 1-4, Oliver Fall 2016 Membre de l'équipe UC Davis, Team 1-4, Oliver Fall 2016
UCD-OLIVER-F16S1G4
4 membres
8 tutoriels rédigés
2 commentaires
The main problem with this repair, is that the keyboard and laptop palmrest/bezel are a sealed unit. You have to remove dozens and dozens of little melted plastic pins to separate the metal keyboard rear plate, and dozens more plastic pins to remove the keyboard from the front bezel itself. And then getting these pins to line up again for assembly is a major PITA. I repair laptops for a living, and I will never try and replace a keyboard on this model again… its just not cost effective. I will seek out the entire keyboard/bezel unit if one of these ever comes to my shop again.
jetskier - Réponse
Excellent point and observation, I have one in now for replacement and luckily had one on the shelf for parts, replacing the whole bezel and keyboard is the way to go!
timdineen -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 20
Total : 5,523
