Aller au contenu principal
HP Pavilion 17-f127ds Optical Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion 17-f127ds Optical Drive Replacement, Battery: étape 1, image 1 de 3 HP Pavilion 17-f127ds Optical Drive Replacement, Battery: étape 1, image 2 de 3 HP Pavilion 17-f127ds Optical Drive Replacement, Battery: étape 1, image 3 de 3
    • Before starting, please turn off your laptop.
    • Slide the battery lock latch, the latch on the left, inwards.
    • Slide the battery release latch on the right inwards to release the battery.
    • The latch may require significant force to slide.
    • Lift the battery up and remove it from computer.
  2. HP Pavilion 17-f127ds Optical Drive Replacement, Optical Drive: étape 2, image 1 de 2 HP Pavilion 17-f127ds Optical Drive Replacement, Optical Drive: étape 2, image 2 de 2
    • Use a Phillips #1 screwdriver to remove the screw holding the Optical Drive in place. It is located near the center and vents of the laptop.
    • Use a spudger to help unseat the drive. Pull the drive out from the laptop.
  3. HP Pavilion 17-f127ds Optical Drive Replacement: étape 3, image 1 de 1
    • If you need to replace the bracket on the Optical drive, remove the two Phillips #0 screws holding the bracket in place. The bracket can be placed on the new drive.
Stephen Brown
Membre depuis le 10/18/17
201 Réputation
2 tutoriels rédigés
Équipe
UW Tacoma, Team S3-G1, Liner Fall 2017 Membre de l'équipe UW Tacoma, Team S3-G1, Liner Fall 2017
UWT-LINER-F17S3G1
5 membres
4 tutoriels rédigés
Un commentaire
I can’t remove the HP Pavilion 17-x016ds Optical Drive. NEED HELP. Is it necessary to remove it in order to remove bottom panel to replace HDD with SSD? Also can’t remove bottom panel.
Nick Koriakin - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 12
Total : 931
